heading out to the local dragstrip tomorrow..
Old May 24, 2006 | 12:39 AM
NorthernXposure's Avatar
Default heading out to the local dragstrip tomorrow..
im hoping to get into the high 12's.. on drag rads.. hopefuly ill have a few vids of the run up on here my tomorrow night... i may be setting my goals to high..
ill be running the build up in my sig w/ full interior an my hefty 280lb *** driving ...
225/50/15 bfg drag rads
Old May 24, 2006 | 02:47 AM
fastvtecCL's Avatar
Default Re: heading out to the local dragstrip tomorrow.. (NorthernXposure)
good luck...
Old May 24, 2006 | 04:27 PM
94rs-turbo's Avatar
Default Re: heading out to the local dragstrip tomorrow.. (fastvtecCL)
retard the timing, bump up the fuel, and the boost and you will be running 9's lol have fun
Old May 24, 2006 | 04:31 PM
JjuuN R's Avatar
Default Re: heading out to the local dragstrip tomorrow.. (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote"> retard the timing, bump up the fuel, and the boost and you will be running 9's</TD></TR></TABLE>
hell yeah Mike, good luck buddy. definately get video and pics! GLHF
Old May 24, 2006 | 04:36 PM
vivid 02's Avatar
Good luck
Don't lift on shifts
Old May 24, 2006 | 05:07 PM
tegratuner's Avatar
Default Re: heading out to the local dragstrip tomorrow.. (vivid 02)
videos of it would be sweet.
Old May 25, 2006 | 10:21 AM
Aquafina's Avatar
Default Re: heading out to the local dragstrip tomorrow.. (tegratuner)
You betteR be fast y0.
16.412 @ 80.90 FTW!
Old May 25, 2006 | 12:11 PM
Default Re: heading out to the local dragstrip tomorrow.. (Aquafina)
13.5@ 100 2.0 60ft's... car comes out of the hole like a madman and tapers of into 4 th gear.. i was running 16 degrees timing and shitty 90oct pump gas...
im ditching the vafc and JUN ecu set up to go with hondata s200... car seems like it wanting to pull back in 4th and i cant get it to run like it should...
next time out ill throw in a bottle of torco or a few gallons of sunoco 104 advance timing to 19 degrees and see what kinda tune i can come up with on the hondata
ill try to get vids posted asap
Old May 25, 2006 | 12:16 PM
RTW DC2R's Avatar
that sucks. mph is definitely on the low side for what ET and whp.
Old May 25, 2006 | 05:16 PM
DontBlink's Avatar
Default Re: (clip the apex)
your tires seem a little big for all motor.
my buddy went from 225/50/15 bfg's to 235/60/15 bfg's and the car lost half a second and 8mph(12.8x@117mph). the one driver said top end felt like the ebrake was on because the car couldnt push through the largers tires. they put the 225's back on and were back where they should have been (12.0x@125mph).
how much tire pressure are you running in them?
Old May 25, 2006 | 05:35 PM
Default Re: (DontBlink)
15 psi... i ran a smaller slick last year and resulted in lower traps w/ the same ET..
i have the 4.7 final drive as well... im gonna tune it on Hondata and go from there... ill keep you guys updated...
Old May 25, 2006 | 10:17 PM
JjuuN R's Avatar
Default Re: (NorthernXposure)
video g'damnit!!
Old May 28, 2006 | 03:01 PM
JjuuN R's Avatar
Default Re: (JUN.R)
hey Mike, did you think i was gonna let this slip into archive or something?? where's the video you promised??
Old May 29, 2006 | 11:30 PM
JjuuN R's Avatar
ahem
Old May 31, 2006 | 07:08 AM
JjuuN R's Avatar
Default Re: heading out to the local dragstrip tomorrow.. (JUN.R)
*nudges Mike*
Old May 31, 2006 | 06:43 PM
tegratuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthernXposure &raquo;</TD></TR><TR><TD CLASS="quote">ill try to get vids posted asap</TD></TR></TABLE>
looks at the calender,
Old May 31, 2006 | 07:18 PM
buddy of a buddy took vids.. in the process of getting them
Old May 31, 2006 | 08:52 PM
itr1236's Avatar
Excited for the little white rocket ship vids
1junkycivic
Sep 5, 2008 12:11 AM
lunatics209
Jul 2, 2007 05:51 AM
infra
Feb 14, 2004 11:32 AM
no show all go
May 30, 2002 07:51 PM
