Worth buying an LS Motor
Old May 23, 2006 | 10:12 PM
DIS-1's Avatar
Default Worth buying an LS Motor
Some guy is selling me a full complete B18B swap really cheap but the motor has been sitting in the car for like over a year without it being turned on. Plus the car didn't have a hood so it has been rained on. Is it worth buying the motor and if so what do I have to do to make it RUN???? Please Help. Thank You
Old May 23, 2006 | 10:59 PM
Takumi Fujiwara's Avatar
Default Re: Worth buying an LS Motor (DIS-1)
I would try to see if he'll let you do a compression test before you buy it. I assume it's in his car because you said it got rained on because he has no hood.
Old May 24, 2006 | 07:38 AM
50SaysHeEatsIt's Avatar
Default Re: Worth buying an LS Motor (Takumi Fujiwara)
If its be exposed to the elements the dizzy will prolly need to be replaced. But a compression test is a good start, are you getting a full swap? Make sure your getting a good deal before buying it.
Good Luck
Old May 24, 2006 | 08:49 AM
b18sihatch's Avatar
motors in japan sit for years without being turned, look at the jdm b16 out of the 88-91.... maybe not all of them but some and they are still good, just dpeends on how the motor was b4 it was stored
lsboost3d3g
Mar 23, 2010 07:30 PM
atmosphere
12
Apr 8, 2006 02:02 PM
SiR Racelot
May 1, 2005 09:19 AM
E-Rok
Feb 6, 2003 03:36 AM
LSBeast
Feb 3, 2003 01:48 PM
