Power Window trouble
Old May 23, 2006 | 03:09 PM
92ehatch's Avatar
Default Power Window trouble
Ive had an ongoing problem with my passenger side power window.
you could roll it down from the passenger side, but not roll it up, i had to use driver side to do that.
well today the driver side window did that, went down, and wouldnt go back up.
i knew it was the switch because down still worked.
so i took out the switch part and peeled out the rubber piece around the switch and looked at the connectors.
the bottom connector (the one that touches when you push the button up) is black.
so i scraped it a bit with a skrew driver, pushed it down some, and hooked it back up.
when i pushed the button, the window worked. HOWEVER that connector got red hot instantly and started smoking. Tried it again and same thing happened.
So the window works, but it gets red hot when the button is pushed.
i believe the problem is the same on the passenger side. but before i take it apart i wanna fix the driver side first.
Im wandering if i will need a new switch, or if anyone knows what could cause that piece to get hot like that and if there might be a way to fix it.
looks like this (mspaint because i cant find my camera)
Old May 24, 2006 | 01:42 AM
92ehatch's Avatar
Default Re: Power Window trouble (93cb7sedan)
bump
lucfleclerc
Apr 25, 2013 01:55 PM
berge
Apr 2, 2006 09:59 PM
TheIntegraGuy
May 15, 2003 06:18 AM
