obd1 conversion...is it even worth it?
if you dont know the benifits of obd1, then you have not done any reading into the subject. before you ask a question like that, know your material, and then, if you are still unsure, ask.
Enables running different ecus and therefore more engine management programs are available. OBD1 also helps with emissions and uses newer electronics which are easier to source when they break.
just so u know the ecu reaspons better to mods, so u get a move power better fuel mix
vtec works way better and must because there not a sohc vtec ecu for 88-91
ok so basically its pointless for my b18a obd0 swap, ohio has no emissions anymore/ and it passed anyways. i figured it might make it run better or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efyou »</TD></TR><TR><TD CLASS="quote">ok so basically its pointless for my b18a obd0 swap, ohio has no emissions anymore/ and it passed anyways. i figured it might make it run better or something.</TD></TR></TABLE>
It may make it run better or if you are getting into heavy mods and need a high end engine management system you would most likely have to convert to OBD1.
ok thx ep3 for not flaming me and actually giving me good advice and info. is it possible to be obd1 ls/vtec? what ecu would i be using then?
a good ecu to use when considering going obd1 is a P28 ecu cause it's has no use of a knock sensor input and are very reliable for tunning it trully pays off in almost any setup ls-vtec will benefit from it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex »</TD></TR><TR><TD CLASS="quote">just so u know the ecu reaspons better to mods, so u get a move power better fuel mix
vtec works way better and must because there not a sohc vtec ecu for 88-91</TD></TR></TABLE>
you sir are an idiot. and on top of that u cant speak english.
odb1 = CROME <- expletive yeah
OBDI ECUs also tend to return better fuel economy.
I converted my hatch over to obd1. I used to have the "famous b16 hesitation" after I converted my car over it went away and the car runs a lot better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote">I converted my hatch over to obd1. I used to have the "famous b16 hesitation" after I converted my car over it went away and the car runs a lot better.</TD></TR></TABLE>
What is that 'famous B16A hesitation'?
o hell no...i remember that when i had my b16 lol. hmmm well maybe i might do it then. wait...i jus bought a new dizzy from dking tho...i dont wanna get another one.
