How do you remove the circle clips for piston wrist-pins?!?
Ok so i got a new set of pistons after the ones i had kinda melted on me and i will be using the same eagles rods i had before. Now how it the world do i take off the clips that hold the wrist-pin in? It looks like a compressed spring and wraps around more than once inside the little groove. I have been trying for about an hour to get one of them off and i just can't. I got them on with no problem but its causing me a real big headache cause i need my car back together as soon as i can.
I use this thing. Its called a scratch awl. But it the same principal as a small flat head screw driver or a pick. I just jam it down under the snap ring and pry it out. Watch your eyes!
thats what i've been using, a really small flat head screw driver, i'm about to just take a dremel to the thing since the pistons are trashed anyways?
the only thing i need is the rods i have new wristpins and everything so i might use a hacksaw/dremel and just cut one side off so i can slip the rod out
Who is Mr Robot?
err... those are for c-clips (snap rings, w/e) the circlips in our pistons dont have holes. they are just pieces of wire bent into a circle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">err... those are for c-clips (snap rings, w/e) the circlips in our pistons dont have holes. they are just pieces of wire bent into a circle</TD></TR></TABLE>ahh, my pistons have the c-clips, i misunderstood the Q then...
funny how you just brought this up tonight, i actually just removed mine because i need the eagle rods only. Extremely easy to get out, i think they're way tougher to put in. I have one of those dentist pick things. Yeah...saw you already got them out though.
well my new pistons use like a circle clip and not the spiral ones and they were pretty easy to get in. And to get the old ones out once i figured it out i could get it them out in under a minute
Vagitarian
Sep 23, 2012 11:59 AM
JalopySiR
Mar 19, 2003 07:21 AM
Ri5e
Sep 7, 2002 07:24 PM
