instalin a head on a d16a6 how to
Old May 23, 2006 | 10:02 AM
orangeracer's Avatar
Default instalin a head on a d16a6 how to
i have a 91 honda an i was wonderin wat is the process of puttin the head on with out fuxkin it up thanks
Old May 23, 2006 | 10:03 AM
EP3_05's Avatar
Default Re: instalin a head on a d16a6 how to (orangeracer)
First step is to get a service manual.
Old May 23, 2006 | 10:58 AM
downest's Avatar
Default Re: instalin a head on a d16a6 how to (EP3_05)
Do you have the head off already?
Assuming the head is off, you need to have it resurfaced at a machine shop (20-30 bucks) and make sure the block is clear of any old headgasket debris. Using a Z6 or Y8 headgasket is best too. Basically you just lay the HG on the block, put the head on top and then tighten the bolts. Start in the middle and work your way out. You need a manual for this, or you could google for CRX_Workshop_Manual.pdf. Do not use copper spray. Also make sure the head and the block are set at TDC so the valves won't hit when you tighten it down.
Old May 23, 2006 | 11:53 AM
how do i make the motor an head at top dead center
Old May 23, 2006 | 11:58 AM
driveahonda's Avatar
Timing marks on the cam gear and crank pulley.
PS: Get a manual.
Old May 23, 2006 | 12:48 PM
i got a manuwell an it doesnt tell me were the pistons should be wen i put the head on
Old May 23, 2006 | 12:50 PM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangeracer &raquo;</TD></TR><TR><TD CLASS="quote">i got a manuwell an it doesnt tell me were the pistons should be wen i put the head on</TD></TR></TABLE>
What manual are you using?? I have the factory shop manual aka the helms manual and it details how to correctly time an engine.
Old May 23, 2006 | 12:52 PM
xaine's Avatar
there are marks on the crank gear
and an arrow or triangle on the block
line those up
the motor is non interferance so you dont have to worry about much else.
Old May 23, 2006 | 04:11 PM
civic_dork's Avatar
Default Re: instalin a head on a d16a6 how to (xaine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaine &raquo;</TD></TR><TR><TD CLASS="quote">
since when?
maybe i'm a moron
not saying you're wrong... just saying i've seen too many D's with bent valves for no clearance issues.
to make sure piston is at tdc, you could always stick a straw, or something in the spark plug hole and make sure it is at tdc... if you're like me and don't really trust the little marks.
Old May 23, 2006 | 04:22 PM
SiRay13's Avatar
Default Re: instalin a head on a d16a6 how to (civic_dork)
do people misspell words on purpose or are people really that illiterate? I'm not a lexicon or anything but I would probably be more helpful if I didn't have to stop reading at every other word to figure out what you're trying to say. Not just this thread but it's all over honda-tech.
Old May 23, 2006 | 04:25 PM
civic_dork's Avatar
Default Re: instalin a head on a d16a6 how to (SiRay13)
How do you know Manu isn't doing well?
.... and why doesn't anyone capitalize their first letter of their first sentence? teehee poke
ps:
search would have found it for you, but maybe it's your birthday, so there's a present.
jyacoba2009
Oct 4, 2009 05:07 PM
Turbo_y8
Feb 25, 2006 10:10 PM
Turbo_y8
Feb 25, 2006 07:11 PM
