HELP - B18A Engine SWAP - 93 civic
Old May 23, 2006 | 06:26 AM
AnTi-RiCeR's Avatar
Default HELP - B18A Engine SWAP - 93 civic
Hey,
I am swapping in a B18A engine and transmission into my 1993 honda civic HB. I have the 2 side motor mounts in, using the integra motor mounts. Now the problem is this:
1. It WAS an automatic. I need to know what pedals to use???
2. The Civic is obd1, the B18A is OBD0. I think keeping the obd0 harness on the engine is good, and keep obd1 ecu. just splice wires???? I need help!!!!!
3. The transmission is CABLE. If I get civic pedals, they will be for a hydro. I have integra pedals for the cable, but they dont seem to fit. I am in a jama s this is my everyday car and has been out of commission all long weekend and now the week.
4. The rear motor mount. What mount do I use? The civic mount I dont think willwork. Will the integra mount work?
5. Any other problems I am going to face ??
Any one can help me? I need some info.
Old May 23, 2006 | 08:33 AM
projectTeG's Avatar
use cable 88-91 ef pedals
Old May 23, 2006 | 10:47 AM
AnTi-RiCeR's Avatar
now is there any one that can help me with my wireing? here is a breakdown:
I have a b18a (obd0) engine, trans, all engine wireing and dizzy. I have a obd1 ecu (b18b1) b18b1 injectors and obd1 stock 93 civic wire harness for the rest. Now how am I going to wire this? Do I splice teh obd0 and hook it up to my obd1 at the firewall on the drivers and passengers side? Is it possible? Where can I find a walk through for doing this. thanks... -Ryan
Old May 23, 2006 | 12:11 PM
projectTeG's Avatar
splice what use the obd1 civic harness on the b18a...use the obd1 injectors,dizzy and ecu and it should plug right up.
Old May 23, 2006 | 12:19 PM
AnTi-RiCeR's Avatar
Default Re: (projectTeG)
so you are telling me that my d15b7 engine harness will plug into a b18a1 engine? I dont think it will. Correct me if I am wrong. Because if that works, I am a happy man!!!
Old May 23, 2006 | 12:28 PM
projectTeG's Avatar
Default Re: (AnTi-RiCeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnTi-RiCeR &raquo;</TD></TR><TR><TD CLASS="quote">so you are telling me that my d15b7 engine harness will plug into a b18a1 engine? I dont think it will. Correct me if I am wrong. Because if that works, I am a happy man!!!</TD></TR></TABLE>
you migh have 1 or 2 plugs not needed and you might need to lenghten some of the plug wires, but all in all it should plug up...i was using a 92 si harness on my poormans ITR swap...now im using a ls harness.
thatkid92
14
Mar 7, 2010 05:34 PM
Yolandita
Oct 28, 2008 11:08 AM
bap168
May 15, 2008 06:41 AM
junior_tm
10
May 14, 2007 03:50 PM
ieldib
Jan 17, 2005 06:31 PM
