is this a bad distributor? pics
Old May 22, 2006 | 06:06 PM
hb_guy's Avatar
Default is this a bad distributor? pics
car
91 civic ex - converted to manual
d16a6 bottom end
d16y7 head = 10.33:1 compression
i/h/e
centerforce df clutch
problem
car does not have power above 5k rpm or so. the motor keeps running but starts to fall flat on its face. also when i let off the throttle in 2nd she bogs a bit. everything is new on the car maintenance wise.
distributor
1. has small oil leak
2. dizzy cap had oil on the bottom side of the cap where it meets the distributor.
3. rotor corroded/rusted
4. cap points don't look good either
5. shaft has questionable play in it.
6. inside of cap had grime and white residue in it.
7. notice how in the 3rd or 4th pic the bottom half of dizzy is greasy and oily? wtf?
replace dizzy all together?? i think that would solve my issues.. anyother advice??
or should i replace cap and rotor first??
thanks everyone - hope the pics help!!
Old May 22, 2006 | 06:15 PM
h224thgensedan's Avatar
the o ring on the dizzy looks shot.
Old May 22, 2006 | 06:48 PM
harmonator84's Avatar
Default Re: (h224thgensedan)
hmm that doesnt look good to me..i think i would change everything out
Old May 22, 2006 | 07:08 PM
Crx Jimmy's Avatar
Default Re: is this a bad distributor? pics (hb_guy)
i had a similar problem, i replaced the o ring and it still leaked just as bad, it turned out it was leaking through the dizzy because the shaft wobbled quite a bit and the shaft had worn so much
Old May 22, 2006 | 07:53 PM
hb_guy's Avatar
Default Re: is this a bad distributor? pics (Crx Jimmy)
anyone else?
Old May 22, 2006 | 10:33 PM
88CRsXy's Avatar
i say distributor o-ring too, i had the same problem with oil under the dizzy. i changed the o-ring and presto, no more leak...also, buy a new distributor cap...both of these parts prolly less than $25 bucks anyways. if it's not that, u can still use the new cap for a future tune-up.
Old May 22, 2006 | 11:30 PM
bigcalidave's Avatar
Bad cap, bad wiring, clean it up real good and make sure that oil is only coming from the distributor, and order the new o-ring. If its not throwing codes, it's probably ok, but definitely leaking.
Old May 23, 2006 | 03:11 AM
crazy sohc vtec guy's Avatar
Default Re: (harmonator84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">hmm that doesnt look good to me..i think i would change everything out</TD></TR></TABLE>
Old May 23, 2006 | 03:20 AM
crxnj's Avatar
just start simple..change the o-ring and see what happens..
Old May 23, 2006 | 03:40 AM
hb_guy's Avatar
Default Re: is this a bad distributor? pics (Mr.speaker)
that's what i am gonna do. thanks
Old May 23, 2006 | 04:32 AM
65stang90crx's Avatar
If you have to buy a new distributor buy it from the Distrubutor King. Hes got a store on Ebay. I give him a . Mine went bad a while ago and his are brand new with upgraded stuff in them. If end up buying new it was about $120.
Old May 23, 2006 | 07:44 AM
boostedSI90hatch's Avatar
Banned
Default Re: is this a bad distributor? pics (65stang90crx)
it sounds like its losing/ or not having a very strong signal if its cutting out at higher rpms??? are you steping on it or its just sputters all on its own?
Old May 23, 2006 | 08:34 AM
ludesrv's Avatar
Change the oring and the cap, the cap has alot of crap and for the price you might aswell change it (They are like 10-15$). Then start her up, let her idle, take her for a boot then check her out. Leaking again, same crap in the dizzy, rip it apart and inspect everything. It just looks like oil and water inside the dizzy, that white stuff. And oil is leaking bas from the o-ring.
Old May 23, 2006 | 11:11 AM
hb_guy's Avatar
Default Re: is this a bad distributor? pics (boostedSI90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedSI90hatch &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like its losing/ or not having a very strong signal if its cutting out at higher rpms??? are you steping on it or its just sputters all on its own?</TD></TR></TABLE>
i am stepping on it.
i changed the cap, rotor, and new wires, new battery too(needed it).
ordered o ring from honda(only place i could find it) - be here tomorrow.
runs better, car no longer sputters - smooth.
it has more power at higher rpms but is still lacking some.
my exhaust has yet to be upgraded, and with my comp i think that is my next step.
i am still getting another dizzy to try, any other suggestions?
Old May 23, 2006 | 06:32 PM
hb_guy's Avatar
anyone else b4 bed?
yangkm
Feb 26, 2011 04:20 PM
Rhood
Jun 16, 2007 02:34 PM
racingfan
Jun 16, 2007 01:51 PM
sailor77
Feb 28, 2007 05:10 PM
2camsaam
Oct 3, 2002 12:34 PM
