exhaust resinator?
Old May 22, 2006 | 04:44 PM
TrunkRattlin's Avatar
Default exhaust resinator?
i have strait pipes but it is too loud, if i add resinators will it have any decrease in hp or torque?
Old May 22, 2006 | 06:01 PM
b18sihatch's Avatar
Default Re: exhaust resinator? (TrunkRattlin)
depends in the piping diameter of ur exhaust. it will be minimual if any
Old May 22, 2006 | 08:29 PM
Default Re: exhaust resinator? (b18sihatch)
diameter is 2.5
Old May 22, 2006 | 08:40 PM
b18sihatch's Avatar
you will notice more of a sound difference than a performance difference if you lose anythnig it would be small nothing noticable
Old May 22, 2006 | 08:41 PM
b18sihatch's Avatar
a smarter thing to do is get rid of the striaght pipe and add a resonator there, as a cat delete.
Old May 23, 2006 | 05:46 AM
well yes the goal would be to make a sound difference, what would it do?
Old May 23, 2006 | 06:43 AM
b18sihatch's Avatar
well if you got a resonator where the cat would be it would be less loud as the test pipe and add harmonic balance to your exhaust. it would be a smarter move that having a test pipe and a resonator if you can get away with jusst the resonator... some ''test pipess'' actually are made like resonators to not be as loud as a normal cat delete
Old May 23, 2006 | 12:37 PM
are you saying leave the cat, or take it out, isnt that illegal? i dont quite understand what you are saying would be good to do
Old May 23, 2006 | 05:47 PM
b18sihatch's Avatar
well your question was, ''i have straight pipes if i go with a resonator will i loose power''
my answer is if you are worried about the noise and power loss
you ''could'' get a ''test pipe'' in the form of a resonator and delete the cat
basicly its like getting rid of the cat to delete any power loss, but having the resonator in place of the cat to tone the sound down
Old May 23, 2006 | 05:53 PM
so add both a test pipe and resinator?
Old May 23, 2006 | 06:32 PM
b18sihatch's Avatar
no, replace the cat converter with resonator
Old May 23, 2006 | 08:40 PM
i wont pass smog then, you have to have a cat. converter
Old May 23, 2006 | 09:43 PM
b18sihatch's Avatar
oh so u are in a state that still does e checks..... then i guess your best bet is to go with the resonator, it wont effect anythnig but give you better sound
Old May 23, 2006 | 09:56 PM
ok thank you for your help, yah im in CA
Old May 24, 2006 | 08:32 AM
b18sihatch's Avatar
yea that sucks i live in ohio and they got rid of e check here thank god.
funny thnig there was alot of guys in the import scene here that worked at the echeck. so they would pass cars that normally wouldnt pass. like supras turbo civics and all that, it was pretty funny.... but then one day they just closed up shop. and that was the end of that
McLaner
Aug 29, 2011 01:18 PM
lPat
Sep 13, 2007 04:33 PM
d.maczko
Aug 12, 2005 08:23 AM
sickofitall1113
May 25, 2005 02:39 AM
Hoosier Daddy
Sep 5, 2003 07:15 AM
