what should i set my toe at??
Old May 22, 2006 | 01:01 PM
big-cat's Avatar
Default what should i set my toe at??
ok so i hear when u lower ur car instead of buying a camber kit u can just adjust the toe to a certaing #. i plan on getting ground control coil over sleeves. and lower my car 2'' so what am i going to want to set my toe at??
Old May 22, 2006 | 01:06 PM
EK k kay's Avatar
Default Re: what should i set my toe at?? (big-cat)
Old May 22, 2006 | 01:12 PM
Spoon-EK9's Avatar
Default Re: what should i set my toe at?? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">0</TD></TR></TABLE>
Old May 22, 2006 | 01:13 PM
big-cat's Avatar
on both back and front? and will my tires ware any more than they are supposed to??
Old May 22, 2006 | 01:18 PM
professor poon's Avatar
Default Re: (big-cat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">on both back and front? and will my tires ware any more than they are supposed to??</TD></TR></TABLE>
there is no toe adjustment in the back. 0 degrees toe, camber is another story though. A little camber can improve your traction without causing TOO much tire wear, but I personally have my camber set at 0 so my tires last as long as possible
loclowd
Jun 2, 2006 08:47 PM
mushu315
15
Dec 12, 2005 04:16 PM
OxYi
Aug 25, 2005 05:59 AM
goofyej6
18
May 27, 2004 05:06 PM
solo-x
16
Aug 28, 2003 04:40 PM
