WATER PUMP REPLACEMENT & A/C BELT REPLACEMENT
Old May 22, 2006 | 10:09 AM
unhappy_idle's Avatar
Default WATER PUMP REPLACEMENT & A/C BELT REPLACEMENT
I have a 1988 HONDA ACCORD ( 2.0L CARB with A/T)
I need to replace the water pump and the A/C BELT.
Can the water pump be replaced on this model of car without the need to remove the timing belt?
Where exactly is the tension adjuster assembly for the A/C compressor drive belt?
Thanks.....
Old May 22, 2006 | 10:16 AM
Ross 2.0's Avatar
In a Junkyard near you.
The water pump is external so you can replace it fairly easilywithout removing the t-belt. Try to find a new one that has the pulley already installed on it.
I've never adjusted the a/c belt on one but the tensioner should be between the a/c compressor and the crank pulley.
metroya_performance
Sep 17, 2007 05:21 PM
lv6l
Oct 14, 2005 11:52 AM
91tegrals
Jan 16, 2004 04:13 PM
parasonic
Jun 16, 2003 06:26 PM
Chairman Kaga
Oct 2, 2001 12:33 PM
