Code 22... any help/advice welcomed...
ok.. ive got a boosted h22... and it has sat all winter in storage and now its up and running again... im running uberdata and the car runs fine.. however im getting a constant cel light and its code 22 which is vtec pressure valve, and obvosly vtec isnt engaging at this point... has anyone ever gotten this code and how do i fix it? would replacing the whole solenoid fix it? thanks guys... and if you think i should post in a different section... please say so...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatchgrl »</TD></TR><TR><TD CLASS="quote">I might check continuity (spelling) from the pressure switch to the ecu and make sure nothing happened to the signal path.</TD></TR></TABLE>
yeah.. i just googled this and found some good info .. im going to check the continuity.. and i guess there is a filter that might need cleaning in the vtec unit itself.. any one else with any info? ( thanks guys)
ViXoN Hatch94
Nov 28, 2005 01:40 AM
