Uberdata a/f ratios not changing while tuning , help!!
Old May 22, 2006 | 04:20 AM
trecool44's Avatar
Default Uberdata a/f ratios not changing while tuning , help!!
Hello, I have been tuning my b16 turbo del sol with uberdata and a plx-m300 and I am having a problem. Right around 5000 the a/f ratio is about 12.3. My target is 11.8. My problem is that no matter what changes I make in uberdata, the ratio never changes. In all other rpms, I have no problem tuning, its just at around 5000, it stays at 12.3. Is there something I am doing wrong, any input will help, thanks alot.
Old May 22, 2006 | 05:17 AM
non-VTEC's Avatar
Default Re: Uberdata a/f ratios not changing while tuning , help!! (trecool44)
how much fuel are you adding in that area? sometimes 1-5% wont make much of a difference since around 5000rpm is usually peak torque and requires the most amount of fuel.
try adding 10-15% of fuel or more and see if it makes a diffrence.......if not there might be a problem with your wideband o2 sensor.
Old May 22, 2006 | 05:45 AM
Tactic$'s Avatar
Default Re: Uberdata a/f ratios not changing while tuning , help!! (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">since around 5000rpm is usually peak torque and requires the most amount of fuel..</TD></TR></TABLE>
I had the exact same problem using uber/plx. I found I had to add quite a bit in that area. (and I assumed it was because of that exact reason)
How much pressure are you seeing at 5000rpm??
Old May 22, 2006 | 06:17 AM
trecool44's Avatar
I'm getting full boost by that point (7psi).
Old May 22, 2006 | 06:59 AM
JFK78's Avatar
Are you datalogging to see what boost column it's actually reading? If you hit peak boost right at that rpm point, it may be be reading in a higher column right there, so you might not be adjusting the correct boost column.
Old May 22, 2006 | 07:14 AM
trecool44's Avatar
Yes I am datalogging and correcting the right columns.
Old May 22, 2006 | 07:55 AM
SOHC_MShue's Avatar
try richening the rows around 5000 as well. Uberdata interpolates between cells to find a fuel value.
Old May 22, 2006 | 10:27 AM
ekhatchgrl's Avatar
What injectors are you using? They might be going static/maxing out.
Old May 22, 2006 | 10:52 AM
trecool44's Avatar
I'm using dsm 450cc injectors, i dont think the duty cycle is anywhere near 100% at the rpm, ill check it when i get home today.
Wicked_CRX
Aug 15, 2003 01:48 PM
