When installing timing belt what can hold the cams from moving?
Old May 22, 2006 | 02:15 AM
SrT4u2nV's Avatar
Default When installing timing belt what can hold the cams from moving?
When installing timing belt what can hold the cams from moving? WHen i installed a timing belt last night after countless hours of tryin to get the belt to fit i finally did and the cam gears r off by three teeth. Is there something i can wedge between the two of them that wont damage them so i can keep them from moving?
Old May 22, 2006 | 11:27 AM
SrT4u2nV's Avatar
bump!!!
Old May 22, 2006 | 03:20 PM
Wes V's Avatar
Default Re: (SrT4u2nV)
I'm not sure about other honda engines, but on a GSR, there is a hole in each of the aluminum cross-bars that connect from cam tower to cam tower. On the factory cams, there is a hole in the cam and if you put the cams at top dead center, you can put a pin (drill bit) through the aluminum piece and into the cam. This holds the cam at top dead center.
Don't forget to remove the pins once done.
Wes V
Old May 22, 2006 | 05:50 PM
x2gold's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure about other honda engines, but on a GSR, there is a hole in each of the aluminum cross-bars that connect from cam tower to cam tower. On the factory cams, there is a hole in the cam and if you put the cams at top dead center, you can put a pin (drill bit) through the aluminum piece and into the cam. This holds the cam at top dead center.
Wes V</TD></TR></TABLE>
correct, with the valve cover remved, put two hex keys in place on the 1&gt; or the first cam retainer closest to the cam gear. This should help a lot. I used drill bits once, just make sure they are strong enough. Also, check a helms if u have reference to one. It lists the exact size. Good luck.
Old May 23, 2006 | 02:42 AM
thahuhstunna's Avatar
Default Re: (x2gold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x2gold &raquo;</TD></TR><TR><TD CLASS="quote">correct, with the valve cover remved, put two hex keys in place on the 1&gt; or the first cam retainer closest to the cam gear. This should help a lot. I used drill bits once, just make sure they are strong enough. Also, check a helms if u have reference to one. It lists the exact size. Good luck.</TD></TR></TABLE>
Old May 23, 2006 | 03:55 AM
NJIN BUILDR's Avatar
Default Re: When installing timing belt what can hold the cams from moving? (SrT4u2nV)
http://www.sjdiscounttools.com/lis36880.html
Auto part stores carry these or a similar tool.
00-501itrspec
Dec 2, 2007 11:33 AM
I got a honda
Oct 25, 2005 04:33 PM
PhazedSI
Sep 19, 2003 06:54 AM
216.226.142.95:27016
Jun 5, 2003 11:18 AM
Propulsion
Mar 23, 2003 10:37 AM
