HPC/JET coatings questions..
Old May 22, 2006 | 12:28 AM
Spec R's Avatar
Default HPC/JET coatings questions..
Well long story short I'm going to have to smog my integra this year. And being that its turbo, I'm probably going to bring it back to stock (what a pain in the ***, but oh well) so it can pass.
While its out, I might as well get some of the exhaust parts coated, like the exhaust manifold, downpipe, and downpipe elbow.
Heres my problem.. My TD05h-18G turbo has a smaaall crack at the wastegate port, so I'm not even going to bother with coating it (even though power output/spool is still good), but will coating the other parts without doing the turbo housing affect expansion/thermal properties in a negative way?
Thanks!
I've read/searched into the topic as much as i can, but i still have these questions...
Modified by Spec R at 1:51 AM 5/22/2006
Old May 22, 2006 | 07:16 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: HPC/JET coatings questions.. (Spec R)
Its not going to cause any problems however, you will see the most benefits from coating the turbine and manifold. I would have to say its not really worth coating the DP. Id just go with some heat wrap to cover the DP in the engine bay till you get to the oil pan.
Not sure if you have gotten prices yet but the turbine and compressor will cost around 65-70 each, the manifold around 125, the WG elbow will be like 30 (outrageous I know), and the DP maybe 140???.
I would just do the manifold and turbo myself.
Old May 22, 2006 | 09:45 AM
Spec R's Avatar
Default Re: HPC/JET coatings questions.. (White Smoke)
great, thanks!
Old May 22, 2006 | 02:25 PM
96ex's Avatar
fot my manifold ceramic coated and all my charge piping powder coated for $150 here in pittsburgh. Its a top mount too so it was really cheap
Sully90SiPrelude
Mar 15, 2007 02:37 PM
rorik
Aug 18, 2005 09:36 PM
projectPSI
Jul 20, 2004 08:54 PM
400WHPITR
Jun 20, 2004 06:44 PM
98lude
Sep 4, 2001 07:35 PM
