PGM-FI relay
Old May 21, 2006 | 06:47 PM
EG6LS's Avatar
Default PGM-FI relay
Does anyone know where the PGM-FI relay or any other relay relating to the fuel pump is located? I have already tested the Main Relay. Please help!!!!!!!!
Old May 21, 2006 | 07:34 PM
Takumi Fujiwara's Avatar
Default Re: PGM-FI relay (EG6LS)
If the EH has it in the same place as the DCs, it should be like a couple inches under the driver's side vent. Just take off the kick panel.
Old May 21, 2006 | 08:03 PM
EG6LS's Avatar
Default Re: PGM-FI relay (Takumi Fujiwara)
I found the main relay. Is it in the same place as the main relay?
Old May 21, 2006 | 09:09 PM
Relic1's Avatar
the PGM-FI relay is the main relay. it controls the fuel pump and power to the ECU and a few engine sensors.
Old May 22, 2006 | 07:41 AM
EG6LS's Avatar
Default Re: (Relic1)
in the schematic for the fuel system there is a relay/resistor between the main relay and the fuel pump. It was labeled PGM-FI relay/resistor.
Old May 22, 2006 | 07:57 AM
Relic1's Avatar
after reviewing the EG manual I'm at a loss what resistor/relay you are refering to.
there is a resistor and diode to feed back to the other coil of the relay to switch it on if there is a signal missing.
But that is internal to the main relay.
if you have the helm manual what page are you looking at?
Old May 22, 2006 | 09:30 PM
EG6LS's Avatar
I went to honda dealer today. One of there service techs told me that sometimes the ECU can just **** the bed. I didn't think that was what happened so I went home and started tinkering with it. I came to a dead end, until my buddy came over and we tried jumpering that diagnostic plug on the passenger side. No code thrown. The book says code 0 ECU failure and we weren't sure so we went and got his B16A ECU just to see what would happen. We hooked it up and BAM the damn thing started and ran. I didn't drive it though cause the B16A ECU threw a code but the engine was still running. I think that the B16A P30 ECU thew a code because it couldn't find the VTEC solenoid. Therefore bringing us to the conclusion that my ECU had failed. I also discovered that the ECU used by the prior owner for the swap was the P06 from the oringinal engine. So I am now waiting for P75 ECU for the LS engine that is in the car.
rick_rabies
Jun 30, 2009 11:08 AM
Discontained
Sep 8, 2006 10:13 AM
DnB TeK
Jun 22, 2005 02:46 PM
markvqwerty
Aug 27, 2004 08:52 AM
PoonHunter
May 15, 2003 02:00 PM
