Hondata rev limiter?
I have searched and found that there is a way to set the rev limiter with the button with the S200. koeo "key on engine off" hit button 5 times, hit brake, set thousands hit brake, set hundeds hit brake, turn key to off position, wait ten seconds, then turn on car.
This hasn't worked for me. The rev limiter is at 8400. I can set it as low as 4000 to see if this way of setting it works and it does. Anyone know why I cant get it above 8400? Ive got a b16 sir2 with skunk2 cams and valvetrain and on the dyno at school it was still making power when it slams into the rev limiter
. By the way so far with stock block it put down 168.53 whp and 111.67 wtq on a dyno jet
Someone help me out here please
http://www.hondata.com/downloads/Users%20Guide.doc
You can set it with the engine running.It's half speed,you rev to 4000 and it will set it to 8000.I haven't done this with the button as I have a romulater and don't reset peak rpm limit very often.I do know it works with flat shift and launch as I have done those on the fly before.
Glenn
Glenn
EF_LSVtec
Apr 16, 2003 09:28 AM
