dumb question ?
Old Apr 12, 2002 | 11:43 AM
jabenne's Avatar
Default dumb question ?
I have a 95 civic EX coupe which engine is that? Its a Vtec I was gonna swap it but now I am thinking about turbo any input I know its SOHC will that be a problem. Any input will be apprec.
Old Apr 12, 2002 | 01:14 PM
rodrez.'s Avatar
Default Re: dumb question ? (jabenne)
It's a D16 motor, single cam vtec. YOur car is heavy, so turbo charging is probably the way to go, but the hybrid hatch guys will probably still run you down, unless you're planning to go all out. I used to have a CRX with an EX motor, ported head, and home made turbo kit (T3/T4), and it was quick, 12.90 at 106 at Pamona. The guy we got the kit from, said it was designed by Ron Bergenholtz, but I doubt it, it was pretty janky, but it did the trick. We smoked many, many cars at the street runs, including a boosted up 3000GT, a few GSX's, and turbo B16 powered Del Sol. We were running 9 lbs of boost full time. Later on, put bigger injectors, and a new computer, got greedy, boosted 12 lbs for about a week, and KA-BOOM! The whole set up only cost us about a grand. The motor was free from a motor swap car. It was a lot of fun, but Know your limits.
Old Apr 12, 2002 | 01:18 PM
Jonathan_ED3's Avatar
it's a d16z6 125 HP
Old Apr 12, 2002 | 01:34 PM
jabenne's Avatar
Default Re: dumb question ? (rodrez)
how long were you running 9lbs? 12.90 sounds nice. have another idea what would be the outcome if I put on a SiR Head which if every thing goes my way will be free and avail soon, then turbo that.
Old Apr 12, 2002 | 01:35 PM
jabenne's Avatar
Default Re: dumb question ? (hot_EF)
Thanks guys for the help
Old Apr 12, 2002 | 01:37 PM
poison's Avatar
SiR head on ur motor??
civic SiR is DOHC, can't put a B series on a D motor.
swap the motor, ur car isn't THAT heavy, but it's heavier than dx, cx and vx's hatches.
Old Apr 12, 2002 | 01:41 PM
jabenne's Avatar
Default Re: dumb question ? (poison)
damn just wishful thinking I guess, so there is no way to convert my D16z6 into DOHC, like I said ( dumb question), without a full engine swap
Old Apr 12, 2002 | 02:00 PM
dirtySOHC's's Avatar
yes.....like tryin to put a square block into a circle hole. you should read in the hybrid and forced induction forums to get some ideas and help you out. you cant just put a turbo in your car if you dont know nothin about it....
Old Apr 12, 2002 | 04:18 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: dumb question ? (dirtySOHC's)
Spend identical amounts of money on a tubocharged D16Z6 and a good DOHC VTEC swap and the swap will beat it every time.
And the swap is still stock, has stronger axles, better tranny, usually newer too with less miles, etc.
Old Apr 12, 2002 | 08:22 PM
MurphDog74's Avatar
what else you have on that cause how does a d series turbo beat a b series turbo?
BoostedEgHatchFl
May 22, 2007 06:18 PM
CTR-GSR
Sep 16, 2005 05:48 PM
civicRtech
Jan 17, 2004 05:52 PM
civicRtech
Jan 17, 2004 05:45 PM
Jaydeep
17
Aug 26, 2003 10:01 PM
