Honda S2000 Honda S2000
best exhaust system for under 900 and should i get dual or single
Old May 21, 2006 | 07:22 AM
regime team's Avatar
Default best exhaust system for under 900 and should i get dual or single
hello i am new to the s2000 scene i use to have a 00 civic si and then i decided to give the s2000 a shot and i love it. Anyway i am saving up money for an exhaust system and i have been looking at the invidia exhaust so i just wanted to get some reviews and advise on what would be my best road to travel on picking the right exhaust thanxs
Old May 21, 2006 | 07:37 AM
Nishant's Avatar
Default Re: best exhaust system for under 900 and should i get dual or single (regime team)
https://honda-tech.com/zerothread?id=1622952
https://honda-tech.com/zerothread?id=1622661
https://honda-tech.com/zerothread?id=1613924
https://honda-tech.com/zerothread?id=1600251
https://honda-tech.com/zerothread?id=1592667
https://honda-tech.com/zerothread?id=1563803
All found within 2 minutes of using the <FONT COLOR="red"> Search</FONT> function located in the upper right hand corner. I know you are new but most things like this have been covered. Please search before making a new thread.
Congrats on the purchase and welcome to the forum!
Old May 21, 2006 | 06:04 PM
negcamber's Avatar
Used to have an Invidia...lots of drone between 3-4k. So bad I would either cruise above 4k or below 3k...and tended to shift a 3k to avoid the drone. Very loud in an unpleasent way. Sounded fantastic at WOT. Is about half the weight of stock exhaust.
I now have a T1R 63mm single and am very happy. Very little drone. Just loud enough to let you know it's there when cruising at 80mph. Sounds great at WOT. Also about half the weight of stock (kind of heavy for a single).
T1R also has a 70mm single that is supposed to be one of the best for making power. May be over your price limit unless used.
If must have a dual, consider the T1R Sparrow. May also be over your price unless used.
Research before you buy. Many aftermarket exhausts for the s2k only add sound. A few are significantly lighter than stock; some are just about as heavy. Many actually cost power...very few have shown real power increases.
Old May 21, 2006 | 07:10 PM
Francesco's Avatar
Default Re: best exhaust system for under 900 and should i get dual or single (negcamber)
keep it stock
Wjbksp8
Honda S2000
25
May 3, 2013 04:40 PM
drmthtr59
Jan 31, 2011 11:02 AM
carrnut21
Northwest (Sales)
Oct 3, 2010 07:06 PM
dohcgarage@714
Honda S2000
Oct 19, 2007 11:38 PM
JpJr BLK-07-Si
Honda Civic (2006 - 2015)
Feb 22, 2007 02:40 PM
