Rim HUB bore too small????
Old May 20, 2006 | 02:12 PM
EKtypeRhaTcH's Avatar
Default Rim HUB bore too small????
friend of mines is putting some rims on his car, and the hub bore on the rim is too small to fit over the hub center. So hubcentric rings wont work on this, correct? What else can he do besides get the hole machined bigger????
Old May 20, 2006 | 04:03 PM
Targa250R's Avatar
be professional
Default Re: Rim HUB bore too small???? (EKtypeRhaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKtypeRhaTcH &raquo;</TD></TR><TR><TD CLASS="quote">friend of mines is putting some rims on his car, and the hub bore on the rim is too small to fit over the hub center. So hubcentric rings wont work on this, correct?</TD></TR></TABLE>
Correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What else can he do besides get the hole machined bigger????</TD></TR></TABLE>
He could try using spacers. Make sure the wheel studs are long enough for the lug nuts to have proper thread engagement.
It shouldn't be expensive to have the hubs bored out at a machine shop though, as long as the place has a 3-jaw or 4-jaw lathe that can hold the wheel.
Old May 20, 2006 | 05:33 PM
old man neri's Avatar
Default Re: Rim HUB bore too small???? (Targa250R)
spacers, rings, and all that stuff will throw your offset way off and your studs may be to short at that point. You may also experiance rubbing. What rims are these? Miata rims by any chance? From other's experiances you can get the centre bored out for 20/rim. Which is not bad. Some people have used a 2-1/4" hole drill bit (the ones you use to but a door **** hole in a door) to bore it out themselves. They claim sucess but I would not recommend it.
Hope it helps,
Cheers?
Old May 20, 2006 | 06:54 PM
thanks for all the info, i dont think we're gonna try and bore them out ourselves. I guess we'll be visiting a machine shop soon. Thanks again
00falcon
Honda Civic (2001 - 2005)
Jul 28, 2008 10:07 PM
WhoisDan
May 7, 2005 02:28 PM
deviant1
May 13, 2003 02:23 PM
Smokinsax
May 7, 2003 11:22 AM
Ya@inlinePRO
May 7, 2003 11:07 AM
