f20b guru's chime in here...
i have a friend thats wanting to boost his f20b. the motor is obd2, we have the conversion harness for it and are using a chipped ecu with uberdata. i want to know if there is anything else that needs to be changed, like any type of sensor or anything, in order to have the motor running properly? or should i be good with just the conversion harness and obd1 chipped ecu?
thanks in advance
daniel
thanks in advance
daniel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude »</TD></TR><TR><TD CLASS="quote">i have a friend thats wanting to boost his f20b. the motor is obd2, we have the conversion harness for it and are using a chipped ecu with uberdata. i want to know if there is anything else that needs to be changed, like any type of sensor or anything, in order to have the motor running properly? or should i be good with just the conversion harness and obd1 chipped ecu?
thanks in advance
daniel</TD></TR></TABLE>
youwere probably better off posting this in the prelude forum. but the first step is that the car is runing good first with not wiring problems or bugs. you can swap the conversion harness in with the chipped ecu and get the car to run first and work out any codes or problems that the obd2 to obd1 conversion causes. then from there boost.
thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 »</TD></TR><TR><TD CLASS="quote">i put an f20b in my obd 1 accord
only had to change a few plugs ,
it runs great off crome. still deciding if i want to boost or not </TD></TR></TABLE>
what exactly did you have to change bro?
**** , umm alt plug , and there was onr more . but i ran itbs so i used a diff tps. and an obd1 map (same anyways)
i did use a obd1 dizzy and obd1 injectors.
so it was pretty easy
Malachi_
14
Sep 25, 2003 04:12 PM
