Could I use wideband output to replace stock ecu wideband signal wire on 2000 honda civic hx?
Can I use a wideband PLX device M-300 with a wideband LINEAR output or a Narrowband analog output to replace the stock wideband sensor signal wire on a Honda 2000 Civic HX ? If I can HOW?
double post.
and you were already told you couldnt and you would a obd2 to 1 conversion to run it......
mariners02
Feb 18, 2012 05:32 AM
milkwasabadidea
Nov 20, 2011 04:24 AM
Honda33442
15
May 23, 2006 08:18 AM
Honda33442
May 22, 2006 05:46 AM
