B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@
Old May 19, 2006 | 09:12 PM
jdmcivicb16a2sc61's Avatar
Default B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@
i have a stock 99 si b16a2. i can pick up some gsr cams for $30 from a buddy. is there a differance in 99 si b16a2 cams vs 99 gsr's? i found there a dif in old b16a and gsr but the question is differance in 99 si b16a2 cams vs 99 gsr's.
oh yea its going to be turbo'd with a ramhorn mani on a 60-1 stg 3 wheel on 14psi
Old May 19, 2006 | 09:15 PM
fmrprojects's Avatar
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (jdmcivicb16a2sc61)
for boost yeah the cams will make a difference but for all motor it wont be none at all
Old May 19, 2006 | 09:16 PM
EM199dcs's Avatar
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (fmrprojects)
I heard they are the same. If you wanna upgrade skunk 2 has some nice cams. Check them out
Old May 19, 2006 | 09:17 PM
yea read somewhere here too that they are the same cams.. i already put them in
Old May 19, 2006 | 10:34 PM
Slow_import's Avatar
well hmmmmmmmm.....i got a 00em1 and i put them in and yea, there is some noticable power, iono i picked them up for 50 bucks and installed them myself all i know is that it gives me more power than my i-h-e-and testpipe....alot of midrange power and top end....i'd say get them....its a good upgrade....i've done it and its worth it.....
Old May 19, 2006 | 11:36 PM
built562's Avatar
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (Slow_import)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_import &raquo;</TD></TR><TR><TD CLASS="quote">well hmmmmmmmm.....i got a 00em1 and i put them in and yea, there is some noticable power, iono i picked them up for 50 bucks and installed them myself all i know is that it gives me more power than my i-h-e-and testpipe....alot of midrange power and top end....i'd say get them....its a good upgrade....i've done it and its worth it.....</TD></TR></TABLE>
riiiight
any butt dyno graphs to prove this.
dont buy them unless you want spare cams, you will not gain anything from it, they are basically the same
Old May 20, 2006 | 11:20 AM
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (built562)
so are the usdm 99 si b16a2 the same cams as gsr? i know they are dif from the b16a or jdm b16 obd0
Old May 20, 2006 | 12:29 PM
Jay_Sensing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">dont buy them unless you want spare cams, you will not gain anything from it, they are basically the same</TD></TR></TABLE>
Not even close to true, there is a decent difference between the two, and there are dyno graphs to prove it.
Old May 20, 2006 | 02:59 PM
93CX's Avatar
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (Jay_Sensing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">Not even close to true, there is a decent difference between the two, and there are dyno graphs to prove it.</TD></TR></TABLE>
anyone got charts?
Old May 21, 2006 | 10:13 AM
VHOA's Avatar
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (93CX)
well if you put the cams in then tune them there is going to be a difference but im pretty sure the cam profiles are pretty close the the same i believe the gsr ones are a little bit more powerfull but nothing noticable
Old May 22, 2006 | 08:37 PM
riiiight
i havent dyno my car yet, but you could feel alot more power in the mid range....and whoever told you that gsr cams are basically the same as 99-00 si's know notting about cams....when i took mine out b4 replacing them, i compared them, the gsr has a bit more lift and duration than the si's....the difference is quiete noticable and well worth the money....
Old May 23, 2006 | 01:10 AM
me too feel the dif in mid range. glad i bought them.
Old May 23, 2006 | 01:13 AM
Orangecivic251's Avatar
riiiight
Old May 23, 2006 | 04:55 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (OrangeCiviC251)
There are dyno charts to prove this. IMO it's just common sense. Cams for a 1.8 are going to be hotter than cams for a 1.6.
riiiight
Go read a ******* Haynes manual, the specs are in there
vw eater
May 15, 2008 09:11 PM
charlay
Oct 9, 2007 01:38 AM
jdmcivicb16a2sc61
May 20, 2006 05:28 PM
jdmcivicb16a2sc61
May 20, 2006 01:27 PM
