B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@
i have a stock 99 si b16a2. i can pick up some gsr cams for $30 from a buddy. is there a differance in 99 si b16a2 cams vs 99 gsr's? i found there a dif in old b16a and gsr but the question is differance in 99 si b16a2 cams vs 99 gsr's.
oh yea its going to be turbo'd with a ramhorn mani on a 60-1 stg 3 wheel on 14psi
Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (jdmcivicb16a2sc61)
for boost yeah the cams will make a difference but for all motor it wont be none at all
Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (fmrprojects)
I heard they are the same. If you wanna upgrade skunk 2 has some nice cams. Check them out
well hmmmmmmmm.....i got a 00em1 and i put them in and yea, there is some noticable power, iono i picked them up for 50 bucks and installed them myself all i know is that it gives me more power than my i-h-e-and testpipe....alot of midrange power and top end....i'd say get them....its a good upgrade....i've done it and its worth it.....
Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (Slow_import)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_import »</TD></TR><TR><TD CLASS="quote">well hmmmmmmmm.....i got a 00em1 and i put them in and yea, there is some noticable power, iono i picked them up for 50 bucks and installed them myself all i know is that it gives me more power than my i-h-e-and testpipe....alot of midrange power and top end....i'd say get them....its a good upgrade....i've done it and its worth it.....</TD></TR></TABLE>
riiiight
any butt dyno graphs to prove this.
dont buy them unless you want spare cams, you will not gain anything from it, they are basically the same
riiiight
Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (built562)
so are the usdm 99 si b16a2 the same cams as gsr? i know they are dif from the b16a or jdm b16 obd0
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">dont buy them unless you want spare cams, you will not gain anything from it, they are basically the same</TD></TR></TABLE>
Not even close to true, there is a decent difference between the two, and there are dyno graphs to prove it.
Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (Jay_Sensing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing »</TD></TR><TR><TD CLASS="quote">Not even close to true, there is a decent difference between the two, and there are dyno graphs to prove it.</TD></TR></TABLE>
anyone got charts?
anyone got charts?
Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (93CX)
well if you put the cams in then tune them there is going to be a difference but im pretty sure the cam profiles are pretty close the the same i believe the gsr ones are a little bit more powerfull but nothing noticable
riiiight
i havent dyno my car yet, but you could feel alot more power in the mid range....and whoever told you that gsr cams are basically the same as 99-00 si's know notting about cams....when i took mine out b4 replacing them, i compared them, the gsr has a bit more lift and duration than the si's....the difference is quiete noticable and well worth the money....
riiiight
riiiight
riiiight
Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (OrangeCiviC251)
There are dyno charts to prove this. IMO it's just common sense. Cams for a 1.8 are going to be hotter than cams for a 1.6.
riiiight
Go read a ******* Haynes manual, the specs are in there
riiiight
jdmcivicb16a2sc61
05-20-2006 05:28 PM
jdmcivicb16a2sc61
05-20-2006 01:27 PM
