B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@
Old May 19, 2006 | 09:11 PM
jdmcivicb16a2sc61's Avatar
Default B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@
i have a stock 99 si b16a2. i can pick up some gsr cams for $30 from a buddy. is there a differance in 99 si b16a2 cams vs 99 gsr's? i found there a dif in old b16a and gsr but the question is differance in 99 si b16a2 cams vs 99 gsr's.
oh yea its going to be turbo'd with a ramhorn mani on a 60-1 stg 3 wheel on 14psi
Old May 20, 2006 | 02:08 AM
jeremydde's Avatar
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (jdmcivicb16a2sc61)
We had both b16a2 and b18c1 cams in the shop which we measured and couldn't notice any differences. Not worth wasting your money or the time to install. We swapped the gsr's in anyways because the head was already apart and didn't notice any differences. Also the a/f measured by the wideband while datalogging didn't change at all before or after the swap.
Old May 20, 2006 | 03:48 AM
bag's Avatar
bag
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (jeremydde)
keep the stock b16a2 exhaust cam,,,but use the 99 b18c intake cam..
the b16a2 exhaust cam has more lift then the 99 b18c exhaust cam,,,but the 99 b18c intake cam has more lift then the b16a2....
Old May 20, 2006 | 11:18 AM
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (bag)
so the 99 usdm si b16a2 cams are dif between gsr..they are not the same?
Old May 20, 2006 | 02:24 PM
mar778c's Avatar
Community Builder
Community Influencer
Gsr cams if the're $50 or less.
Old May 20, 2006 | 05:28 PM
chadmasterc's Avatar
Default Re: B16a2 Cams vs Gsr cams.....tired of searching@$#@%$#@%#@%@%@ (mar778c)
http://www.evans-tuning.com/comp3.html
I would go with the gsr cams for boost.
redyute
Jul 7, 2013 09:16 AM
10psiLsEf2
Oct 26, 2012 07:57 PM
MugenHonda
Northeast (Sales)
Jul 6, 2006 08:34 PM
jdmcivicb16a2sc61
13
May 23, 2006 04:55 AM
jdmcivicb16a2sc61
May 20, 2006 01:27 PM
