Name these parts.
Old May 19, 2006 | 06:46 PM
pinecone's Avatar
Default Name these parts.
Is this an SI hub? If it is what other parts does it look like I might need.
Anyway to find out what tranny housing this is.
Is this a D-series alternator?
These are two wires that have been hanging out since I got the car. I am not sure what they go to. One wire looks like a ground, its black. The other is yellow and green.
Old May 19, 2006 | 07:46 PM
thevtecnician's Avatar
Default Re: Name these parts. (pinecone)
Does your reverse lights lights work? They might be reverse lights. On the exhaust side of the tranny are its counterparts. If not that than they go to the back of yor block. Next to the oil pressure line.
As for the rest I would have to be there to I.d.
Old May 19, 2006 | 07:51 PM
bustedefhatch's Avatar
Default Re: Name these parts. (thevtecnician)
yea looks like reverse light wires. count the teeth on the hub i got an si axle in the garage i can see if its the same teeth si and dx are the same only std is different. on the casing next to the fill plug theres a couple circles with lines through them with stamped numbers and letters what do they say?
Old May 23, 2006 | 04:34 AM
pinecone's Avatar
Default Re: Name these parts. (bustedefhatch)
Can anyone show me where the reverse lights are hooked up to?
Yes that is a SI hub, what other pieces do I need? OR is it just plug and play?
Old May 23, 2006 | 04:42 AM
njcrxsi's Avatar
2 wires go 2 fan switch at bak of blok
Old May 23, 2006 | 05:26 AM
pinecone's Avatar
Default Re: Name these parts. (brijpurt13b)
So those are the fan switch wires? If they are I have no need for them, my fan is on a switch.
Old May 23, 2006 | 02:58 PM
CLE's Avatar
CLE
Those are the reverse light sensor wires, there is a sensor on the tranny the plug into.
Old May 23, 2006 | 03:10 PM
pinecone's Avatar
Default Re: (CLE)
Where on the tranny?
Old May 23, 2006 | 03:43 PM
88 rex's Avatar
Default Re: (pinecone)
front, lower part of the tranny.
Old May 23, 2006 | 04:01 PM
shortyz21's Avatar
Default Re: (88 rex)
all wrong, lookit the little rubber bungs on the wires. that means those were pulled out of a main plug somewhere along the lines..
they go in one of your main plugs somewhere.. as to where count each wire on each plug.
if your car runs fine with no cels. who gives a **** what they do
Old May 23, 2006 | 04:08 PM
BlueCrxNC's Avatar
The Tranny Case is a non-90-91 Si case. Could be 88-91 HF, DX, or 88-89 Si. Reason? Uses the smaller 72mm OD Differential Bearings. Do you have the internals? If so, look at the Mainshaft that would connect inside the clutch disk. There are X # of rings on the tip of the shaft for specific years.
Old May 23, 2006 | 04:29 PM
pinecone's Avatar
Default Re: (BlueCrxNC)
They go to a plug, hmm, I will look into what plug may be missing these.
But are they the fan switch plug wires or the reverse light wires? Because those wires are not going to reach to the lower front part of the tranny.
No I don't have the internals, that is all I have. Wish I knew what tranny I went to, then I could help anyone that had a busted open tranny case.
Old May 23, 2006 | 05:03 PM
crxnj's Avatar
did you click that pic that brijpurt13b posted.?? you can clearly see the black and green/yellow wires plugged into the fan switch..keep clicking the pic untill it gets huge
Old May 23, 2006 | 05:14 PM
pinecone's Avatar
Default Re: (Mr.speaker)
Yea I did. But everyone was like it was the reverse light wires. But since my fan is switch controlled, I don't care.
Old May 23, 2006 | 05:26 PM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">did you click that pic that brijpurt13b posted.?? you can clearly see the black and green/yellow wires plugged into the fan switch..keep clicking the pic untill it gets huge</TD></TR></TABLE>
those connections dont got the rubber bung like the main plugs do..
Old May 23, 2006 | 05:29 PM
crxnj's Avatar
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">
those connections dont got the rubber bung like the main plugs do.. </TD></TR></TABLE>
the previous owner probably pulled them out the fan switch,,and they came out or broke,,and he just put on some other connectors..
Old May 23, 2006 | 06:13 PM
pinecone's Avatar
No idea, but now I know what wires they are. Thanks guys.
Old May 24, 2006 | 06:28 PM
BlueCrxNC's Avatar
Anybody can still use that tranny case providing that they use the smaller bearings. They will of course need to re-shim everything.
Old May 24, 2006 | 08:11 PM
pinecone's Avatar
So anybody besides a 90-91 si can reuse it? Hmm, alright.
hondahustle
May 25, 2008 02:48 AM
fasterthanrayswrx
Feb 2, 2007 06:27 PM
Giga Crusher
Apr 25, 2005 10:37 PM
P_t0wn
Jul 15, 2003 02:17 PM
PimpTightSi
Sep 29, 2002 06:56 PM
