Oil Seal, not sealing? non-vtec build
Motor:
B18B1
Head milled .040
Rocket valve springs
Crower 404's
PR3 pistons, arp rod bolts,new rings
ect.ect.ect..
So this motor was recently put together and dropped in.
Once it got to the tuner. They found out that seals 1-3-4 did not seal. Has anyone had this problem? Any reason why ? Just thought I'd ask, befor pulling out the motor and tearing it down.
B18B1
Head milled .040
Crower 404's
ect.ect.ect..
if you are talking about rings.give us somemore info like if you honed the cylinder or not. it takes a good 500 miles to have a 100% acurate compression test after rings are instslled.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR831 »</TD></TR><TR><TD CLASS="quote">what seals? valve cover seals (ones that go over the spark plug holes) or valve seals? </TD></TR></TABLE>
Piston rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest »</TD></TR><TR><TD CLASS="quote">if you are talking about rings.give us somemore info like if you honed the cylinder or not. it takes a good 500 miles to have a 100% acurate compression test after rings are instslled.</TD></TR></TABLE>
Yes it was honed. Didn't want to drive it,because there is zero miles on this build, and with the higher c/r, thought it be safer to get it tuned first. Thats the problem now. Can't tune it since the rings havn't sealed.
Piston rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest »</TD></TR><TR><TD CLASS="quote"> it takes a good 500 miles to have a 100% acurate compression test after rings are instslled.</TD></TR></TABLE>
compression was 230 across the board,the day it was suppose to get tuned.
typeeg
Jun 9, 2004 02:33 PM
