'92 VX died and won't start
So, I'm driving down the street at about 40 mph, car is running fine, suddenly engine dies. I pull over and try to restart it. It cranks but won't start. Timing belt is fine. I check for spark and I'm not getting one. I check the resistance on the ignition coil. The primary is within spec, the secondary is a little high on Ohms. I could just buy a new coil and try it out, but the parts stores around here won't let me return it unless it's defective. So, if I try it and the car still won't start, I out about $80.
Do I need a distributor? How do I check it? I happen to have a distributor from my '88 CRX project sitting around, would that work? Thanks for any help!
Thanks. I never looked too close at the battery cables. I'll check them tomorrow. The car is parked at the repair shop I work at.
Anyone else have any ideas? I've heard of ignition coils and distributors going bad, but don't they usually give a little warning? This thing was running fine, then just stopped and refused to restart.
the thing is the corrosion can be anywhere on the cable. Mine was about 10-12 inches from the alternator and not at the connector. Just better off replacing it anyways, the cable is 14 years old lol.
smokez187
Aug 10, 2007 11:35 AM
ace42004
34
Apr 11, 2005 02:57 PM
