how do you know when its time for a new sub?
Old May 19, 2006 | 01:54 PM
Jer'rome's Avatar
Default how do you know when its time for a new sub?
I have a 12" kickersolobaric s12c ive had for a few years now, but i bought it used, It still hits hard no problems. My question is what happens to a sub when it gets too old?
Old May 19, 2006 | 02:37 PM
john666's Avatar
Default Re: how do you know when its time for a new sub? (Crunk'd)
it gets old & u get use to the sound & want something stronger is what i think.
Old May 19, 2006 | 02:42 PM
8520's Avatar
When it gets sloppy or blows up.
Old May 19, 2006 | 02:51 PM
02 accord's Avatar
Symptom: not playing as loud as it used to
-surround/spider get stiff and restrict movement of the cone.
-resistance of the voice coil increases (less power going to the driver).
Symptom: scraping sound
-When the spider/surround deteriorate, the voice coil alignment will get screwed up.
-The glue might release, screwing up the alignment of the voice coil in the gap.
-The wires of the voice coil might come off the former.
Symptom: not playing at all
-fried voice coil.
-broken wires somewhere on the sub.
Old May 19, 2006 | 03:32 PM
fcm's Avatar
fcm
Old Fart
Well if it still hits hard, then it may be old but thats all.
All speakers are about the same, and they get "old" in the same places, and a lot of things have to do with what gets "old", when. Everything from how they are installed to how they are powered to how they are played will have an effect on them.
The number one thing that goes wrong with most speakers is the VC, they can be burnt, from misuse, [putting too much power to them (watts) or driving them with an underpowered amp that is being driven into clipping for long periods of time, The VC can also become "delaminated", [also from excessive heat from overpowering or under-powering] The VC can be misaligned, [improper mounting of speaker] it will rub the walls of the VC gap.
The next most common is just plain wear and tear, on the surround, [outside edge of speaker, glued to the cone and the speaker basket] kind of like a "hinge", the material that it's make of can/will be effected by movement, humidity, [or lack of] and sunlight, [UV] and physical damage.
And less common is the spider, [connected to base of cone and speaker basket] it is also susceptible to wear and tear from movement and it's material can be effected by the environment around it.
Think of a speaker as a motor, if you take real good care of it it will last for a long time, but, eventually it will wear out.
You do not have a problem with a speaker until you hear things that should not be there, or stop hearing things that should be there. 94
Old May 20, 2006 | 02:12 PM
Jer'rome's Avatar
Default Re: how do you know when its time for a new sub? (fcm)
thanks for the replys.. i think m gonna keep my sub
Old May 20, 2006 | 03:37 PM
fcm's Avatar
fcm
Old Fart
If it's still working, why not..... 94
Old May 22, 2006 | 07:19 AM
Tizzlers Ep3's Avatar
You know the sub is broke, the day you didnt buy a w7
Old May 22, 2006 | 05:16 PM
draperj09's Avatar
Default Re: how do you know when its time for a new sub? (Tizzlers Ep3)
when new subs start sounding a thousand times cleaner. if you got money get you some fosgate punch stage 3 or new kicker solo baric's
Old May 24, 2006 | 03:36 PM
cynistersix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tizzlers Ep3 &raquo;</TD></TR><TR><TD CLASS="quote">You know the sub is broke, the day you didnt buy a w7</TD></TR></TABLE>
W7? pssh. go big or go home
Old May 24, 2006 | 06:01 PM
shyboy817's Avatar
Is that the MTX Jackhammer? MTX 9500?
Old May 25, 2006 | 12:44 PM
Default Re: (shyboy817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 &raquo;</TD></TR><TR><TD CLASS="quote">Is that the MTX Jackhammer? MTX 9500?</TD></TR></TABLE>
lol yeah. what a stupid idea. "hey want to get rid of your back seats put this in your car, you may even have to remove your passenger front seat if you drive an EG"
Old May 25, 2006 | 11:52 PM
Punk0Rama's Avatar
and it is way overpriced for the performance. i would take a W7 over the jackhammer any day of the week.
Old May 26, 2006 | 11:20 AM
shyboy817's Avatar
Damn just looked up, the jackhammer is like 7,999$
dallasyoung
Audio / Security / Video
16
Sep 3, 2017 10:20 AM
lee0149
Dec 29, 2008 10:29 PM
InfamousCivic
May 29, 2007 06:58 PM
dabigrog
Aug 17, 2004 06:11 PM
LuderCriS
Jul 27, 2002 12:39 AM
