turbo turbine ....too big?for ls motor?
Old May 19, 2006 | 09:16 AM
importdude2000's Avatar
Default turbo turbine ....too big?for ls motor?
stock ls motor
i found out my turbo is a 54trim oe .63 AR stage 3!
the turbo rebuilders told me that stage 3 wheel is gonna lag like ****..like 5k fullboost becuase of the stage 3....usally .63 stage one is fine
hes telling me i should go with a .48 AR
boost will be at around 3!
my goals are <250 so i would like boost to be around 3.......
for the smaller wheel its gonna cost
$100+my 63 turbine+turbine housting
for new GARRETT parts
should i do it?
i just dont wanna loost traction due to it spooling too fast
Old May 19, 2006 | 10:12 AM
ham's Avatar
ham
Default Re: turbo turbine ....too big?for ls motor? (importdude2000)
since its a stock LS motor and your goals are less than 250hp, i would just leave it. even if you change the wheel, youre not going to get power at 3k rpm. i say save your money!
Old May 19, 2006 | 11:24 AM
bump need help fast
Old May 19, 2006 | 12:15 PM
ham's Avatar
ham
Default Re: (importdude2000)
if you dont like my advice then change it out!
Old May 19, 2006 | 12:45 PM
Default Re: (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">if you dont like my advice then change it out!</TD></TR></TABLE>
i just wanted more response
no offence
Old May 19, 2006 | 02:15 PM
yee SERIOUS's Avatar
maybe keep the wheel. get smaller exhaust housing? you can change the spool time if you run 2.25inch ic pipes instead of the general 2.5inch. also 3inch downpipe
Old May 19, 2006 | 02:52 PM
TheShodan's Avatar
Moderator
Its the compressor wheel, that would cause a problem with "lag". In this case, though you're fine. Keep it as it is...
Old May 19, 2006 | 09:27 PM
desiromeo812's Avatar
Default Re: (TheShodan)
if you not lookin for hella power get greddy turbo 18g bro... full &psi at like 2800 rpm.. mated with abigger DP and exhaust... shyt pulls.. for a DD good power
Old May 20, 2006 | 08:26 AM
SL0WEGG's Avatar
Default Re: (desiromeo812)
i dont know how good the power will be at 3psi
t0ng0
Mar 3, 2007 06:04 AM
SpoolnByYou
Nov 17, 2005 02:29 PM
JerKeK9
Oct 12, 2004 05:12 PM
Flr Power
Apr 3, 2004 01:33 PM
MR. ARIZONA
Aug 18, 2003 10:41 AM
