OT: so i had to call in sick... was left stranded 5 houses down
Old May 19, 2006 | 03:17 AM
John Z's Avatar
Default OT: so i had to call in sick... was left stranded 5 houses down
my alarm went crazy and wouldnt let me drive, i got 5 houses down my block and the car just turned off and siren going crazy at 545 in the morning (im sure my neighbors love me even more now) so i had to use my limited amount of sick "frequencys" i guess its a good time to call around looking for a place to install a new one today..
and i dont even drive the car daily, just that the subaru was hit by a taxi 3 weeks ago and im waiting for the body to be fixed...
Old May 19, 2006 | 04:16 AM
CW-ITR's Avatar
You could have pulled the alarm fuse and reset the computer and drive to work...I think...
Old May 19, 2006 | 04:30 AM
John Z's Avatar
Default Re: (CW-ITR)
ill try that, i just dont know if it wil work because its one of those cliffords with all those bells and whistles..
if that doesntw ork ill pull the computer, all the alarm stores open late.
(atleast its back in my driveway, had it towed back )
Old May 19, 2006 | 04:46 AM
Mr.Wrench's Avatar
Default Re: OT: so i had to call in sick... was left stranded 5 houses down (Yaz)
Damnn sorry 2 hear.
Old May 19, 2006 | 06:56 AM
Green JDM-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">You could have pulled the alarm fuse and reset the computer and drive to work...I think...</TD></TR></TABLE>
This is partially true.
You need to pull the alarm fuse (usually inline with the red wire).
You won't need to reset the computer (i guess u mean ecu).
You will need to reconnect the starter wire under the dash though. When alarms are installed the starter is cut for the starter kill relay.
If you need any other help with this matter let me know
Old May 19, 2006 | 07:50 AM
John Z's Avatar
thanks for the help, i called a few shops and 1 had the switch i needed for the "blackjax" box..
when i tried unpluging the alarm ECM the car was 100% dead, so i had no choice but to get the part, so i just finished putting the switch in and the car is good again, but i must say this system works very well,
Old May 19, 2006 | 08:02 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Yaz)
You towed it a couple of blocks? What happened to manual labor? Push that thing
Old May 19, 2006 | 08:30 AM
B2FiNiTY's Avatar
Default Re: (Yaz)
What exactly did you have to replace? I'm guessing that the part failed on you.
Old May 19, 2006 | 08:36 AM
JjuuN R's Avatar
wow that's some scary stuff, if you find out exactly what happened i'd like to know. imagine that happening with 3 sirens
mugenpowered
16
Aug 27, 2006 09:32 AM
sL1cK
Oct 27, 2005 07:34 PM
dukers
Audio / Security / Video
25
Aug 4, 2005 09:38 PM
jeffk182
Sep 16, 2004 11:41 AM
Undercover_Skank
Apr 3, 2004 06:16 PM
