Brake Line help needed
Old May 18, 2006 | 07:49 PM
BoostinEJ1's Avatar
Default Brake Line help needed
Basically I need to go from 12mmx1.0 Male to 10mmx1.0 Female to connect my ABS MC to my non ABS line. Any help would be great.
Old May 19, 2006 | 01:29 PM
BoostinEJ1's Avatar
anyone
Old May 19, 2006 | 01:32 PM
Targa250R's Avatar
be professional
Default Re: Brake Line help needed (simple DB2)
Cut the end off the line, remove the 10mm fitting, put a 12mm fitting on, and reflare the line. You'll need a tubing cutter and a flaring tool. Search "brake line flare" on Google.com and you'll find several tutorials on the procedure.
Old May 19, 2006 | 05:10 PM
BoostinEJ1's Avatar
i dont know how to flare sadly, anyone else?
Old May 20, 2006 | 12:47 PM
BoostinEJ1's Avatar
anyeoneee?
Old May 20, 2006 | 12:50 PM
Targa250R's Avatar
be professional
Default Re: (simple DB2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple DB2 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know how to flare sadly, anyone else?</TD></TR></TABLE>
If you're not willing to learn, then get a different MC. Or buy a different brake line.
Old May 20, 2006 | 01:28 PM
schardbody's Avatar
if you refuse to do a simple brake line flare leave your honda stock, it will save the next owner the headache of fixing all the problems you created.
Old May 20, 2006 | 01:35 PM
BoostinEJ1's Avatar
its not that a refuse i simply dont have a clue. a fitting seemed the easiest cheapest way which makes sense to me.
Old May 20, 2006 | 01:37 PM
schardbody's Avatar
then run down to the local parts store and ask for a fitting. when they say they dont have it pick up a flaring tool and read the directions, its like a 5 minute job.
Old May 20, 2006 | 05:53 PM
BoostinEJ1's Avatar
well i sucked it up and tried my hand at flaring and it seems as all went well. ill see for sure tomorrow when i put fluid in it and go for a drive.
Old May 20, 2006 | 09:51 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple DB2 &raquo;</TD></TR><TR><TD CLASS="quote">well i sucked it up and tried my hand at flaring and it seems as all went well. ill see for sure tomorrow when i put fluid in it and go for a drive.</TD></TR></TABLE>
Let us know how it goes.
Old May 21, 2006 | 09:38 AM
schardbody's Avatar
told you, nothing to it.
jdmark1
Jun 22, 2018 03:37 PM
ESP.net
Suspension & Brakes
May 29, 2010 09:19 PM
BlitzSix
12
Jul 1, 2009 10:55 PM
hondazccivic
Aug 21, 2008 11:41 AM
1991civicsi
May 4, 2006 06:52 PM
