need help
Old May 18, 2006 | 04:53 PM
KingHonda's Avatar
Default need help
okay new to the site but have a few questions. i did a mini me swap on my 99 dx and put an ex head. the first couple days car ran fine vtec popping and all. but latley the past month the vtec is not popping i know u cant here it to much on a single cam but u hear no change over for the vtec or anything. would any body else know what the problem could be
Old May 18, 2006 | 07:18 PM
92_VX_EG's Avatar
Default Re: need help (KingHonda)
Is the car wired for vtec? Are you using the vtec dizzy? Are you running a vtec ecu? Did you use the right timing belt for the ex head? Did the head have any bent valves? Need to know a little more info before it can be analyzed.
Old May 19, 2006 | 03:39 PM
KingHonda's Avatar
car is wired for vtec has vtec dizzy with vtec ecu the timing belt is correct. nothing wrong with the head its good just stopped popping vtec and dont know y
Old May 20, 2006 | 07:20 PM
KingHonda's Avatar
anybody know the problem need help
Old May 20, 2006 | 07:31 PM
EG93si's Avatar
low oil, clogged solenoid, bad oil, easy way to see if it is actually engaging is to tap the green wire from the solenoid, run it to the car to like a led, wire in a 330 ohm resister (could be wrong on that resister) and then ground it. when vtec engages, it should light up. gl
Old May 21, 2006 | 04:53 PM
KingHonda's Avatar
Default Re: need help (EG93si)
thanks man tryed what u said vtec kicks over good had a short in the wiring but got it going and running strong
BoltSOCpower
Oct 24, 2010 03:06 PM
bobbyisda1
Aug 4, 2009 02:32 PM
Suck my DX
Jan 6, 2005 10:34 AM
ek9 ferio
20
Mar 10, 2004 06:01 PM
barto
Jun 1, 2003 12:03 PM
