water temp guage
i installed my sir gauge cluster and b16 into my crx at the same time so i am not too sure of what is caussing this but as soon as i turn my key to on the water temp guage max's out, i dont see anything that it could be out on, so i was wondering if i could just run a new wire from the gauge to the sensor, or do i need to run somthing to the ecu as well?
Mine does the same thing , but , I never took the gauge out.
It just went up one morning and has done it every sense.
The shitty thing is when it happened I thought I ran it hot , even took it to my machanic and told him to pull the head , replace the head gasket , and go ahead and do the water pump , timing belt , ect. why he had it apart.
Oh well , she was due for the timing belt and water pump anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex-Si »</TD></TR><TR><TD CLASS="quote">Mine does the same thing , but , I never took the gauge out.
you are probobly grounding out somewhere follow the wire and see if it is worn anywhere
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 »</TD></TR><TR><TD CLASS="quote">
you are probobly grounding out somewhere follow the wire and see if it is worn anywhere</TD></TR></TABLE>
its ran in the main wire loom , hard to see.
What if I ran a new wire , would that work if I used good wire and butt connectors.
yep, when fully unrestricted ground applied it will max out.
mine has an intermitting grounding problem, i tap the cluster clear cover and it goes normal, hit a bump and up to H she goes.. on and on.
96romaEK
16
Mar 18, 2010 08:36 PM
