car idles iracticaly, need help!
Old Apr 11, 2002 | 10:06 PM
carcala's Avatar
Default car idles iracticaly, need help!
anyone know what it could be when my ildle goes up and down during start up on a b16 with a ITR manilfold and TB, also does it sometimes when hot. i start my car and idles fine but as soon as i step on the gas it starts idling iratically. sometimes when i start it up it does it right away. when i drive for a few minutes it stops and idles normally but very low. I tried just about everything to try and fix the problem. i changed my IACV 3 times using different ones. tired the one from a del sol vtec and LS but made it worst. checked my tps sensor and map sensor they were fine. checked for a leaking intake gasket that was fine too. Everytime i try to adjust my idle screw to increase my idle it would get worse. I need help on this so if anyone knows what it could be let me know. i need to fix this problem ASAP.
Old Apr 11, 2002 | 10:59 PM
JALOP B16's Avatar
Default Re: car idles iracticaly, need help! (carcala)
Check o2s and tps thats what caused mine. o yeah check vacume leaks..
Old Apr 12, 2002 | 01:22 PM
iwhichisme's Avatar
check you TB and intake manifold gaskets, almost sure that is the problem. you have a slight leak
Vash121991
Mar 6, 2012 03:33 PM
93daintegra
Oct 23, 2008 12:38 PM
asianrepnsb
12
Mar 8, 2008 12:26 PM
646EG
Jan 19, 2008 07:13 PM
dominikano24
Dec 25, 2005 08:57 PM
