which brake lines to adapt 1" master cyl to non abs eg civic??
i'm trying to find out which brake lines are used between a 1" master cylinder and the proportioning valves on a non abs eg civic (had a 13/16 mc previous w/4 wheel disc.) anyone done this before??
i already went to acura and ordered the first 2 lines from a 94 gsr. they go straight from the master cyl to the abs pump.... which is no good for me. i was thinking maybe the rs integra because it doesn't have abs.. but i'm not sure whether it has the 1" mc or not and whether the lines have the same configuration.
An RS integra has a 15/16" master cylinder. I was told that it will bolt up to a non abs EG civic perfectly. I don't know about the lines. I would stick with the RS master cylinder. A 1" is not much bigger and the RS requires no bending of lines.
Mark
Mark
hmmm.. too late. i already have the 1" master cyl. i guess i'll just end up bending the lines... unless someone knows something i don't know.
dustinbs144
Mar 6, 2011 06:08 PM
JDM_SOHC
25
Apr 20, 2007 09:52 PM
Another Drew
Jul 4, 2005 06:35 PM
