will a z6 oil pan fit on a y8?
Old May 18, 2006 | 09:17 AM
SRd240sx's Avatar
Default will a z6 oil pan fit on a y8?
will a z6 oil pan fit on a y8? tia
Old May 18, 2006 | 09:23 AM
Jorsher's Avatar
Default Re: will a z6 oil pan fit on a y8? (SRd240sx)
Um I'm about 99% sure but not positive. Don't see why it wouldnt...
Old May 18, 2006 | 09:25 AM
Eaglekper0046's Avatar
Default Re: will a z6 oil pan fit on a y8? (Jorsher)
All d-series pans should be the same. It dosent matter where the dipstick is.
Old May 18, 2006 | 10:00 AM
SRd240sx's Avatar
Default Re: will a z6 oil pan fit on a y8? (Eaglekper0046)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eaglekper0046 &raquo;</TD></TR><TR><TD CLASS="quote">All d-series pans should be the same. It dosent matter where the dipstick is.</TD></TR></TABLE>
I believe there is a difference between VTEC and non-VTEC oil pans, but I'm not sure if they are interchangable or not.
Hmm OK i just wanted to confirm if it will work because mine is leaking. Can anybody else confirm?
Old May 18, 2006 | 10:05 AM
ReDemoN's Avatar
DixielandImports Please
i dont think they are.
Z6 ones are steel
Y8 ones are aluminum
i think that is the difference in them.
Old May 18, 2006 | 10:09 AM
Default Re: will a z6 oil pan fit on a y8? (ReDemoN)
my y7 was steel, im put my y8 alum pan on, with my turbo kit
Old May 18, 2006 | 10:12 AM
The Internet Tough Guy's Avatar
it will fit but you'll need the z6 oil pump as well. the y8 pan sucks and the oil pump doesn't pump oil very well either. lots of y8s with spun bearings, not so many z6s.
Old Aug 7, 2006 | 04:56 AM
Charlie Moua's Avatar
Default Re: will a z6 oil pan fit on a y8? (The Internet Tough Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Internet Tough Guy &raquo;</TD></TR><TR><TD CLASS="quote">it will fit but you'll need the z6 oil pump as well. the y8 pan sucks and the oil pump doesn't pump oil very well either. lots of y8s with spun bearings, not so many z6s.</TD></TR></TABLE>
true?
Old Aug 7, 2006 | 05:11 AM
Terrible One's Avatar
Default Re: will a z6 oil pan fit on a y8? (Charlie Moua)
very true
Old Aug 7, 2006 | 05:19 AM
F20Cteg's Avatar
Default Re: will a z6 oil pan fit on a y8? (Terrible One)
Also, even though the Y8 has an aluminum pan, it is way heavier than any of the steel pans.
AaronGeisinger
Jun 20, 2011 07:28 AM
THEDirtyDseriesWOOT
Dec 17, 2006 04:46 PM
sirsol66
15
Sep 11, 2006 09:59 AM
