1997 Accord Power Window Problem.....
Old May 18, 2006 | 09:17 AM
ramoneguru's Avatar
Default 1997 Accord Power Window Problem.....
I have a 1997 2dr with power windows (f22b2).
It appears the passenger side window does not roll UP when I use the master switch (the one tht controls all windows on the driver's side). However, it does ROLL DOWN when I use the master switch.
It will also roll up/down when using the passenger side window switch. So, I imagine there are 2 window motors (1 for the driver and one for the passenger).
This doesn't look like a motor problem since the window can roll up/down without the master switch. Would this be a connection to the switch problem or a connection to the motor that operates the window type of problem?
Old May 18, 2006 | 09:25 AM
JDM_CD7's Avatar
Default Re: 1997 Accord Power Window Problem..... (ramoneguru)
Funny because i'm having the same problem in my 95 Coupe.
I can control the pass. window from the master switch but not from the pass. door.
i changed the master switch/pass. switch and did all the trouble shooting procedures in the Honda Manual and nothing.....
Guessing it can also be the motor on the window, that will be getting replaced soon
In to see your fix
Old May 18, 2006 | 01:35 PM
ramoneguru's Avatar
Default Re: 1997 Accord Power Window Problem..... (JDM_CD7)
Yeah, I don't even have the EVTM to look at so I guess I'll be using logic on this one *shrug*
Old May 18, 2006 | 03:21 PM
MasterCrx's Avatar
I think the windows on accord are cursed...I found that my driver window rolls down quite fast, but when rolling it up it stops about halfway and its like i have to let it recharge....so it sits for a while then goes up slowly...I have found then when my headlights are on it wont roll up at all....so when i turn them off the window rolls up slowly but surely....
Old May 18, 2006 | 04:58 PM
hondadude's Avatar
To address your problem and not the other two THREAD JACKERS; it really sounds like the master switch is the problem. There is only one motor for each window, the wiring is configured to make the master switch the 'boss', and the individual window switches are ganged in to the circuit. If you are going to remove the drivers door panel to test the master switch output you can repost and ask for the info or check out 'hondahookup' for schematics.
Old May 18, 2006 | 07:51 PM
ramoneguru's Avatar
Default Re: 1997 Accord Power Window Problem..... (hondadude)
Awesome, thanks. I'll be doing it tomorrow. I'll be sure to get pics as well.
Old May 20, 2006 | 02:47 PM
JDM_CD7's Avatar
Thread Jackers?
If you have no type of helpful input the STFU.
I have the wiring diagrams and troubleshooting procedures if you need them.
LMK
EndlEEsss
Feb 23, 2023 03:46 AM
1nice96
Dec 30, 2012 08:14 AM
bmclean1
Feb 22, 2011 04:42 PM
deetzracing
Jan 16, 2011 08:46 AM
TheIntegraGuy
May 15, 2003 06:18 AM
