quick question for anybody with an F22B1 and some way of getting pressure at the MAP (VAFC, SAFC, ga
Old May 18, 2006 | 08:57 AM
mmmVTEC's Avatar
Default quick question for anybody with an F22B1 and some way of getting pressure at the MAP (VAFC, SAFC, ga
i just need to know what the pressure at your MAP sensor is at WOT (100% throttle). i think i have a leak somewhere... but mine's now at -1.0 or -1.1 psi. this is NA obviously. thanks much!
Old May 18, 2006 | 10:43 AM
notoriousB's Avatar
Default Re: quick question for anybody with an F22B1 and some way of getting pressure at the MAP (VAFC, SAFC
I've never driving my car N/A with an AFC but what values are you expecting under load? I'd expect it to be approaching 0 (atmospheric pressure).
Are you sure you're seeing PSI and not mm/hg values for vacuum readings?
Old May 18, 2006 | 11:19 AM
mmmVTEC's Avatar
yea it's in PSI, you can pick your unit of measurement with the AFCs. you're right, it should and does approach 0, but i'm thinking maybe it should be closer to 0 than mine is. idling i think it's around -9.5 PSI, and engine braking causes like -12.5 PSI. i'm actually about to go drive somewhere to check up on another issue i'm having, so i'll recheck those numbers.
Old May 18, 2006 | 11:33 AM
mmmVTEC's Avatar
so yea...just rechecked. below are the common ranges.
WOT: -1.0, -1.1 PSI
idle: -10.5, -11.0 PSI
engine braking: -12.5, -12.8 PSI
a vacuum leak somewhere would explain some of the problems i'm having so if somebody could throw down some numbers for comparison that'd be great...
Old May 21, 2006 | 12:26 AM
mmmVTEC's Avatar
anybody? seriously this would take 2 seconds for anybody with a VAFC/SAFC/etc hooked up, or even a vacuum/boost gauge. thanks
Old May 21, 2006 | 07:59 AM
notoriousB's Avatar
Default Re: (mmmVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmmVTEC &raquo;</TD></TR><TR><TD CLASS="quote">so yea...just rechecked. below are the common ranges.
WOT: -1.0, -1.1 PSI
a vacuum leak somewhere would explain some of the problems i'm having so if somebody could throw down some numbers for comparison that'd be great...</TD></TR></TABLE>
I was doing some tuining yesterday, and while i"m boosted, these numbers all seem right to me. obviously WOT I see boost but I think -1 psi is about right for WOT n/a.
if you had a manifold leak your car wouldn't idle right at all.
Old May 24, 2006 | 10:16 PM
mmmVTEC's Avatar
well it only idles right like half the time...the other half it's surging like mad and/or killing itself. but if those pressures match maybe it's not the vacuum pressure. doh.
Old May 30, 2006 | 10:46 AM
mmmVTEC's Avatar
aright, so i swapped the stock fuel injectors back in thinking i'd need to send the DSMs off to get cleaned. when i took them out i noticed the seals were loose, like they'd expanded after i installed them. also, my WOT intake mani pressure with the stock injectors is consistently -0.8, -0.9 PSI. so now i'm thinking maybe it's just leaky seals. thoughts?
Initial_drift
May 18, 2008 07:31 PM
The Weather Man
Aug 13, 2005 10:45 AM
99lspwr
Oct 24, 2003 09:12 AM
_Endless_
May 16, 2003 06:24 PM
Spudddy
May 16, 2003 12:21 PM
