++ Wire Tuck Question ++ Fuse Box??
Old May 17, 2006 | 05:36 PM
EG MikE's Avatar
Default ++ Wire Tuck Question ++ Fuse Box??
I am currently doing a wire tuck on my eg right now and I am stopping until I figure out where to put the fuse box. I see the people w/o the fuse box in the engine bay but have no clue where they hide it?
Cliff Notes:
Where do you relocate the fuse box? (hidden)
Theres like no room under the dash..?
Old May 17, 2006 | 05:58 PM
Luserkid's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (EG MikE)
What i did was relocate it to where the ecu normally goes then relocated the ecu somewhere else
Old May 17, 2006 | 06:55 PM
EG MikE's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (Luserkid)
Do you happen to have a pic of how it fits?
Thanks for the comment man!!
Old May 17, 2006 | 09:21 PM
playalindask8er1's Avatar
ive actually seen people put it in their glove box...but they werent usin the glove box for anything so it worked out perfectly for them
Old May 18, 2006 | 05:08 AM
manueliscool's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (playalindask8er1)
Whats the engine bay lookin like now?
Old May 18, 2006 | 05:37 AM
the jdmchop's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (manueliscool)
most of them remove the heatercore to do so
Old May 18, 2006 | 06:55 AM
gabebauman's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (jdmchop)
I'd say in the glove box or under the passenger side air bag panel.
Old May 18, 2006 | 07:39 AM
EG MikE's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (gabebauman)
Ya i thought about the glove box, but would have to chop it up to fit it in there..
As for the air bag ,, im making a daily driver with a/c, and the stock airbags heh so yea
And for pics of the engine bay check out my post on the whole rebuild:
https://honda-tech.com/zerothread?id=1620009&page=2
Thanks guys
If anyone has any pictures can you post them up??
Thanks, mike
Old May 18, 2006 | 05:32 PM
EG MikE's Avatar
bump
Old May 18, 2006 | 06:41 PM
EG MikE's Avatar
Default Re: (EG MikE)
Has anyone seen it done in another gen of honda/acura?
Old May 19, 2006 | 04:23 AM
yo bro theres a huge thread on wireless bays !
Old May 19, 2006 | 01:32 PM
EG MikE's Avatar
Default Re: (jdmchop)
Im just looking for the fuse box ,,, Ive already read like 20 "wire tuck" threads and didnt find any info on them.
-mike
Old May 19, 2006 | 03:12 PM
lazybrown187's Avatar
ITS GONNA BE A STRETCH
Old May 19, 2006 | 04:49 PM
jarel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">most of them remove the heatercore to do so </TD></TR></TABLE>
thas what i've seen and heard. theres basically no room under the dash with the heatercore still there. but i'd stick that badboy in the glovebox. Easy access...and easily replaceable.
Old May 19, 2006 | 05:29 PM
Soccerking3000's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (jarel)
mines in the glovebox and i can still use it just fine i got my manual and all that stuff still in there
Old May 21, 2006 | 04:33 PM
EG MikE's Avatar
Default Re: ++ Wire Tuck Question ++ Fuse Box?? (Soccerking3000)
Anyone have a pic of it located in the glovebox and how much did you cut?
-mike
Old May 21, 2006 | 05:13 PM
5lugSlug's Avatar
why cut? just screw it to the back and drill a hole for wire
Old May 21, 2006 | 05:25 PM
graveltravel2's Avatar
why not just do a write up on how to do a wire tuck????
how come nobody has done one yet?
Old May 21, 2006 | 05:28 PM
Default Re: (i need a new username)
you have to cut, because of the way the glovebox slopes and becomes less deep at the base so the box wont fit
and i have mine in the glove box
Old May 21, 2006 | 06:49 PM
EG MikE's Avatar
Default Re: (Soccerking3000)
Also do you take it out to change fuses? or is it mounted so you can get access w/o doing that?
Old May 21, 2006 | 07:59 PM
carbonk20's Avatar
I have a 93 Eg hatch and i removed the heater core, blower motor and much of the vent work. I mounted mine facing towards the floor behind the glove box. Its attached to the support bracket for the dash. Its easy to get at and change fuses and I still have full use of my glove box.
Old Jan 5, 2007 | 04:56 PM
Fuster_Cluck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonk20 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 Eg hatch and i removed the heater core, blower motor and much of the vent work. I mounted mine facing towards the floor behind the glove box. Its attached to the support bracket for the dash. Its easy to get at and change fuses and I still have full use of my glove box.</TD></TR></TABLE>
Any pics?
Sorry to bump this old thread. Like the original thread starter said, this is the only thread that deals with EG specific / fuse box relocation
I also would like to relocate the battery under the dash. Heater core is coming out
Oh damn!! Just realized this is Mike with the blue EG. What's up man? Did you ever finish the tuck??
Old Jan 8, 2007 | 01:57 AM
Mr.Eg6's Avatar
any pix?
Old Jan 8, 2007 | 05:35 AM
b16a1eg6's Avatar
Default Re: (SexyEgSix)
I put my fuse box in where the A/C condensor is.
Old Jan 8, 2007 | 07:13 AM
DJ_SaNdOz's Avatar
Default Re: (b16a1eg6)
You could probably mount it under the passenger seat if you wanted, it may make it more of a PITA to check the fuses, but if you are considering putting it where the heater core goes I doubt you care about that.
