***HELP!! Open stud stuck in the back of my block/ d16z6
Old May 17, 2006 | 02:31 PM
.kyle's Avatar
Default ***HELP!! Open stud stuck in the back of my block/ d16z6
hey you guys. . . i've come to the end of a road. . i dont know what else to do. . i tried to use a cheap oil feed line kit. with an open stud and a brass t fitting. . the problem is that i threaded it in. . then bought a new oil line kit from stealthmode. . so i needed to take the t fitting and stud out. . well the t fitting came off. . and now the stud is stuck in the back of my block. . i have tried so much to get this thing out. . i have pictures right now of me drying a bolt onto the end with JBweld. . i also tried using two nuts interlocked. . unfortunately there arent enough threads sticking out for that. . so i even tried to JB behind one nut but that seemed to fail also. . .i also tried using an "easy-out" BUT there is such limited room behind my block that i cant fit anything back there to un-twist it out. . . THE STUD IS DIRECTLY ABOVE WHERE YOU WOULD PUT THE OIL FILTER. i need any other suggestions you have on how i can get this out of my engine!!! so i can run my turbo civic!! THANKS FOR THE HELP!!
here are the pics:
sorry for the bad pictures. .
Old May 17, 2006 | 09:33 PM
integraswtrde's Avatar
Default Re: ***HELP!! Open stud stuck in the back of my block/ d16z6 (IWantATurbo)
remove your axle and your half shaft! a little more room to work with.worst situation take motor out.
Old May 18, 2006 | 12:10 AM
ironcheftony's Avatar
vice grips'
SAMCRO08
Apr 24, 2012 02:51 PM
jarven93
Dec 12, 2006 12:47 PM
.kyle
May 18, 2006 08:46 PM
.kyle
May 17, 2006 05:39 PM
ls95hatch
Jul 18, 2004 10:49 AM
