Replaced timing belt now I have a whirring noise
Old May 17, 2006 | 07:29 AM
wrsimmons21's Avatar
Default Replaced timing belt now I have a whirring noise
I replaced my timing belt 5 days ago and made sure to set the tension right by rotating the camshaft sprocket back 3 cogs. I am 100% positive everything is lned up perfectly. The car starts strong (which shows that the belt is tight enough) but when I am in idle and driving it makes a whirring noise from the belt area. It almost sounds like a turbo charger (except my car doesn't have one). Does anyone know what this could possibly be? What did I do wrong? Thanks, Joe
Old May 17, 2006 | 07:39 AM
Default Re: Replaced timing belt now I have a whirring noise (wrsimmons21)
I forgot to mention I replaced the tensioner and water pump. It is a 1994 Accord LX with 200,000 miles
Old May 17, 2006 | 08:10 AM
Ross 2.0's Avatar
In a Junkyard near you.
The timing belt is WAAAAY too tight.
Old May 17, 2006 | 08:27 AM
Default Re: (MooGoCow3)
Can I loosen it by loosening the tensioner or do I need to redo the tension with the camshaft too?
Old May 17, 2006 | 08:42 AM
Ross 2.0's Avatar
Just loosen the bolt and let the tensioner relax a little more, or just back it off completely and apply a little finger pressture then torque it back down (be sure the timing doesn't jump a toth).
Old May 17, 2006 | 08:48 AM
TouringAccord's Avatar
H-T Order of Merit
To readjest the tension, loosen the adjusting nut (located just above the crank pulley) 1 turn. Then turn the crankshaft CCW 3-teeth on the camshaft. Then tighten the adjusting nut back down.
Old May 17, 2006 | 05:10 PM
hondadude's Avatar
I'll bet dollars to dimes the counter balance belt is waaaaay too tight.
Old May 17, 2006 | 10:06 PM
fe519's Avatar
Default Re: (hondadude)
it dont think it might be too tight. i think you did it correctly. i have experienced some timing belt noise after a brand new timing belt but usually goes away after a while as time passes. If it drives and feels fine, its probably fine. just give it some time to break in
Old May 18, 2006 | 03:57 PM
73sport's Avatar
Default I second the op that its Tooo Tite
I second the opinion that its Tooo Tite!
Measure the deflection so you have a reference for the future (after it stretches).
randy
Old May 21, 2006 | 03:47 PM
I went back in there and loosened tensioner, pushed it in to release tension, went back 3 cogs and tightened the bolt back down. It doesn't make that bad of a noise now so I think it will work itself out here in a few thousand miles. Thanks for your help all.
Psycho719
Sep 14, 2011 04:28 AM
WiedemannC
Dec 6, 2010 12:35 PM
lsturboswap
Sep 3, 2007 04:49 PM
89sparks
Aug 31, 2007 06:44 PM
Hawaiian1
Feb 20, 2004 09:53 AM
