Bad Map Sensor???
Old May 16, 2006 | 08:08 PM
dizzyek's Avatar
Default Bad Map Sensor???
So my cars been bogging and hesitating for while only under load and I cant seem to figure out the problem. The only code i have is iat I fixed that but still the problem. So today I unpluged the map sensor then started up the car and drove it all day WTF. My car drove the exact same as it did before. Does this mean my map sensor is bad?
Also I looked at my coolent reservoir and it looked a little dark I took a look inside and it was a brownish greenish color.......what does this mean?
Old May 16, 2006 | 08:31 PM
axtran's Avatar
hum, no CEL eh? you could be leaking through gasket with that dirty coolant.
Old May 16, 2006 | 08:49 PM
dizzyek's Avatar
what about the map sensor? I drove with it unplugged and nothing changed. This must mean I have a problem with the map sensor.
Old May 17, 2006 | 07:52 AM
dizzyek's Avatar
bump
Old May 17, 2006 | 09:36 AM
dohcdelsol93's Avatar
Default Re: (dizzyek)
if your not throwing a cel I'd say it's probably ok. When was your last tune up? If your plugs are fouled or the gap has grown way too big the engine will cruise/idle fine but will hesitate/jerk badly when accelerating under load.
Old May 17, 2006 | 09:38 AM
Default Re: (dohcdelsol93)
https://honda-tech.com/zerothread?id=1290468
this will tell you how to check your tps and map
jay-d-em
Sep 7, 2006 05:07 PM
GQ 05YellowEVO8
Jul 12, 2001 09:23 AM
