stupid amp question
can i run 4 alpine type-x speakers throgh a multi-channel amp and share a 10" alpine sub with that same amp or would it be safer to just run two amps...one for the speakers and a 2 ch.mono amp for the subwoofer....thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">if you run a full pass signal through the sub it will mess up the voice coils.</TD></TR></TABLE>
No it won't. It will just sound like ****. And to answer the original question, run 2 amps.
IT WILL ALSO OVER LOAD THE VOICE COIL WITH TO MANY SIGNALS IN THE RANGES IT WAS NOT INTENDED TO PLAY.IN TURN IT WILL OVER HEAT THE COILS AND BURN THEM OUT.I HAVE SEEN IT HAPPEN.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">IT WILL ALSO OVER LOAD THE VOICE COIL WITH TO MANY SIGNALS IN THE RANGES IT WAS NOT INTENDED TO PLAY.IN TURN IT WILL OVER HEAT THE COILS AND BURN THEM OUT.I HAVE SEEN IT HAPPEN.</TD></TR></TABLE>
Too many signals? My sub is only getting one signal. It is composed of multiple frequencies, but it's only one signal. And the voice coil is an inductor. And inductors filter out high frequencies. You don't seem to know about this stuff, so I guess it's pointless to argue about it.
If you're so sure about it, why don't you take any sub, hook it up to a full range signal, and then look at its output with a spectrum analyzer. How much high frequency content will you see (by high frequency I mean above 10 kHz)?? None. That's because the inductance of the voice coil will filter that out.
You have probably seen people turn up the gain too much, and the clipping amp took out the voice coil. Full range signal or not makes no difference.
Afterthought: how do you overload a voice coil with too many signals?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">IT WILL ALSO OVER LOAD THE VOICE COIL WITH TO MANY SIGNALS IN THE RANGES IT WAS NOT INTENDED TO PLAY.IN TURN IT WILL OVER HEAT THE COILS AND BURN THEM OUT.I HAVE SEEN IT HAPPEN.</TD></TR></TABLE> OK two things. First, STOP YELLING we can hear you, second, tell whoever told you that not to quit his day job, or if his day job has anything to do with audio he should quit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsouyporta »</TD></TR><TR><TD CLASS="quote">can i run 4 alpine type-x speakers throgh a multi-channel amp and share a 10" alpine sub with that same amp or would it be safer to just run two amps...one for the speakers and a 2 ch.mono amp for the subwoofer....thanks </TD></TR></TABLE> That depends on the amp you are talking about, there are 2ch amps that you can do it with, [passive x-overs will be needed for both the high-pass, ["alpine type-x speakers"] although they could run full range, [to the Type-x x-overs] but the sub would need at least a coil, [low-pass x-over].
If it is a 4ch amp, 2 channels can be used for high-pass and the other 2 can be bridged into mono to run the sub, [again depending on amp].
However I agree with the others, the best way would be 2 amps, one 4ch amp to run the high-pass, [the 4 type-x speakers] and a mono block, [1ch amp] sub amp for the sub.
94
BTW "a 2 ch.mono amp" is an oxymoron, is it not?
One more thing, there are no stupid questions, just STUPID ANWERES
94BTW "a 2 ch.mono amp" is an oxymoron, is it not?
there are a few mono block amps on the market today that can run sub frequencies and speaker frequencies simultaneously:
mtx's adaptive series
orion 600d
expect to pay a pretty penny for these the mtx series start at 289.95 for a 250 watt amp
just go with fcm's advice and get a good mono block amp AND a dedicated speaker amp
orion 600d
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> BTW "a 2 ch.mono amp" is an oxymoron, is it not?
Nope. A 2 channel mono amp is an amp with 2 channels, both of which get the same signal. A 2 channel monoblock is 2 separate amps in one chassis (power supply and amp for each channel).
</TD></TR></TABLE>Nope. A 2 channel mono amp is an amp with 2 channels, both of which get the same signal. A 2 channel monoblock is 2 separate amps in one chassis (power supply and amp for each channel).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord »</TD></TR><TR><TD CLASS="quote">
Nope. A 2 channel mono amp is an amp with 2 channels, both of which get the same signal. A 2 channel monoblock is 2 separate amps in one chassis (power supply and amp for each channel).</TD></TR></TABLE> LMAO, And I though mono meant one ch. or 2ch mixed, [bridged] into one, how could I be so wrong the last 30+ years of installing car audio
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> And I though mono meant one ch. or 2ch mixed, [bridged] into one, </TD></TR></TABLE>
So you're saying that taking 2 amps, putting them in one chassis, and sending them the same signal can't be done? To me, that would be a 2 channel mono amp.
I guess that it depends on how you look at it. If you're looking at line-level signals, sending the same signal on both left and right is mono. Then you would have 2 mono channels. But when looking at amps, mono would mean only one channel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">how could I be so wrong the last 30+ years of installing car audio
94 </TD></TR></TABLE>
That's what I'm trying to figure out too
94 </TD></TR></TABLE>That's what I'm trying to figure out too
yea i wanna know this stuff too so yur saying that a 2 mono the signal is equal to both channels not like a 2 channel(stereo)amp?
</TD></TR></TABLE>yea i wanna know this stuff too so yur saying that a 2 mono the signal is equal to both channels not like a 2 channel(stereo)amp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r »</TD></TR><TR><TD CLASS="quote">so yur saying that a 2 mono the signal is equal to both channels not like a 2 channel(stereo)amp?</TD></TR></TABLE>
That's what it seems like to me. The amp might have left/right inputs, but they are summed to a mono signal. Then that mono signal is fed to both channels of the amp. That's why it would be called a 2-channel mono amp. A regular 2 channel amp (stereo) will also have left/right inputs, but each one of those goes to a separate channel.
OK this is getting out of hand, if you had 2 mono-block amps in one case and an input for each amp and plugged in the left signal into one and the right signal into the other one and connect the left side speaker (s) to the output of the mono-block with the left input and the right speaker (s) to the mono-block with the right input, you would have stereo, but you would still have 2 mono-block amps, not a 2ch mono-block amp, the same goes if the input signal is mixed, ["summed"] before it goes into the amps, you still have 2 mono-block amps, not a 2ch mono-block amp, [maybe dual or twin mono-block] mono means one....
mono prefix 1 one, alone, single [monocracy right out of the Webster
In the 30+ years I have been installing car audio, this is the first time I have heard the term 2ch mono amp.
nuff said.94
nuff said.94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">OK this is getting out of hand</TD></TR></TABLE>
Not really.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">if you had 2 mono-block amps in one case and an input for each amp and plugged in the left signal into one and the right signal into the other one and connect the left side speaker (s) to the output of the mono-block with the left input and the right speaker (s) to the mono-block with the right input, you would have stereo, but you would still have 2 mono-block amps, not a 2ch mono-block amp</TD></TR></TABLE>
Then it can be either. What would be the difference? It's the same thing, so call it what you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">the same goes if the input signal is mixed, ["summed"] before it goes into the amps, you still have 2 mono-block amps, not a 2ch mono-block amp</TD></TR></TABLE>
2 mono-block amps means 2 separate amplifiers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">mono prefix 1 one, alone, single [monocracy right out of the Webster
As I said before, it depends on what you look at; the signal or the amp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">In the 30+ years I have been installing car audio, this is the first time I have heard the term 2ch mono amp.
nuff said.94 </TD></TR></TABLE>
So people are supposed to use the same words/phrases over and over and not come up with new ones? That would get boring after a while.
Not really.
</TD></TR></TABLE>As I said before, it depends on what you look at; the signal or the amp.
nuff said.94 </TD></TR></TABLE>So people are supposed to use the same words/phrases over and over and not come up with new ones? That would get boring after a while.
Boy I sure needed a good laugh today. a few thoughts:
- There are such animals as dual mono amps ...research the amp company
Genesis-the are very popular with the SQ crowd
- Hit RF's(Rockford Fosgate) website and click support. Search Rockford System design. You will come across a set of system designs on how it used to be done...
before mono blocks and digital surround processors. The designs were taught by RTTI ( Rockford Technical Training Institute) back in the day!! FCM was right,passives xovers will be needed...but how cool was it to do the ultimate system and have it run off a 15 watt X 2 amp!!!! Man those were the days.
Have fun. 25yrs and counting
.- Hit RF's(Rockford Fosgate) website and click support. Search Rockford System design. You will come across a set of system designs on how it used to be done...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">All the memphis mclass amps, the 250d ,500d,100d and so on are the same.they are mono block amps but have two channels.</TD></TR></TABLE> I think you are confusing 2 rca inputs and/or 2 sets of speaker outputs with 2 channels the amps are mono blocks one channel you can see it at their site on their spec sheets EG; the 16-MCD250 is 125x1 into 4 ohms or 250x1 into 2 ohms, 1 meaning one channel not two channels.
94
94
That's so you can hook up a standard stereo signal (which will get mixed to mono). 2 sets of speaker outputs are there so you can hook up 2 subs in parallel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord »</TD></TR><TR><TD CLASS="quote">That's so you can hook up a standard stereo signal (which will get mixed to mono). 2 sets of speaker outputs are there so you can hook up 2 subs in parallel.</TD></TR></TABLE>BINGO we have a winner, Hey, Don Pardo, tell our contestant what he has won, well Dave, for getting that one, contestant number 3 wins this certificate, in this beautiful mahogany frame that states The above named person KNOWS WHAT THE HELL HE"S TALKING ABOUT.
Back to you Dave, whats the next stupid amp question?
94
94
