Still having fuel problems....
Old May 16, 2006 | 04:51 PM
f22 lx's Avatar
Default Still having fuel problems....
I posted abuot 2 weeks ago with my fuel problem, and it didn't seem to get better, I barely got 275 miles on my last tank....3 tanks ago I got 325 miles, 2 tanks ago 300 miles, tank before last got 275 miles again. There are no CEL's and my driving habits are fairly normal no excessive revving or anything I try to keep it around or under 2500 rpms, what would you recommend getting checked out?
1995 Accord LX Coupe AT 143k
Modified by f22 lx at 11:44 AM 5/17/2006
Old May 17, 2006 | 10:44 AM
f22 lx's Avatar
any help?
Old May 17, 2006 | 10:50 AM
notoriousB's Avatar
Default Re: (f22 lx)
change your fuel filter, run some injector cleaner through the system, don't press the gas pedal so hard (lol), do a full tune up if you haven't in a while.
Old May 17, 2006 | 11:48 AM
Slunk's Avatar
Default Re: (notoriousB)
check your air filter
Old May 17, 2006 | 01:10 PM
f22 lx's Avatar
ive ran fuel injector cleaner through the tank about a tank ago, and my air filter and spark plugs are almost brand new, a major tune up was done about 9k-10k ago
Old May 17, 2006 | 02:02 PM
Perfectionist's Avatar
Default Re: Still having fuel problems.... (f22 lx)
I don't know from miles per tank. Normally, fuel economy is measured in miles per gallon.
After having ruled out all the obvious fuel wasters, (tire pressure, ignition, timing, mechanical deficiencies, etc) I would suspect the primary O2 sensor.
Old May 17, 2006 | 02:12 PM
f22 lx's Avatar
Default Re: Still having fuel problems.... (Perfectionist)
generally if the O2 sensor wasn't working properly a CEL would come up, because I thought that would haev been the problem...
I was considering a new fuel filter, but it seems that they are really hard to install from what I've read...
Old May 17, 2006 | 02:17 PM
Slunk's Avatar
It's a long shot but your odometer could be failing.
I had to replace mine at around 22k and it would stick on a certain mileage for a while and then work fine.
From what I have read it is not an uncommon problem on 5 gen accords.
Old May 17, 2006 | 02:26 PM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22 lx &raquo;</TD></TR><TR><TD CLASS="quote">I was considering a new fuel filter, but it seems that they are really hard to install from what I've read... </TD></TR></TABLE>
don't be a wussy. check your fuel filter.
Old May 17, 2006 | 02:31 PM
f22 lx's Avatar
Default Re: Still having fuel problems.... (f22b2power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2power &raquo;</TD></TR><TR><TD CLASS="quote">It's a long shot but your odometer could be failing.
From what I have read it is not an uncommon problem on 5 gen accords.</TD></TR></TABLE>
I've already replaced it with a fresh one about 16k miles ago...
The fuel filter will be checked...
Old May 17, 2006 | 09:15 PM
f22 lx's Avatar
any other ideas?
Old May 17, 2006 | 09:36 PM
mmmVTEC's Avatar
Perfectionist mentioned it off-handedly, but increasing your tire pressure decreases rolling resistance. if your tires are low on air it could be decreasing your fuel economy.
Old May 19, 2006 | 01:26 AM
BlUAc's Avatar
Default Re: Still having fuel problems.... (mmmVTEC)
check your ect sensor it is under the distrubitor
Old May 19, 2006 | 01:19 PM
ck123's Avatar
does replacing fuel filter actually help increase gas mileage???
if so where can it be found?
how much does it cost to replace?
RI-Gixxer
26
Feb 4, 2010 03:16 PM
jyacoba2009
12
Jan 13, 2010 08:05 AM
dirrtybirdy
Dec 4, 2007 06:09 PM
_Cyclone_
Jan 29, 2005 09:10 AM
pbizzlegsr
Jul 24, 2004 07:17 AM
