Exhaust fitting question
Old May 16, 2006 | 04:44 PM
Shake and Bake's Avatar
Default Exhaust fitting question
I just ordered my motor and wasnt sure what will still fit. I have a few aftermarket parts already on my d series. I already found out the intake wouldnt fit, but will my full cat back skunk2 exhaust bolt up to a b18c1 motor? The exhaust is for a 98 ex coupe.
Old May 16, 2006 | 05:17 PM
bump
Old May 16, 2006 | 06:04 PM
Default Re: (AllstockSIke)
Old May 16, 2006 | 06:19 PM
93b18civic's Avatar
Default Re: Exhaust fitting question (AllstockSIke)
should be fine depending on the header you have on the new motor. stock header will work fine. aftermarket header depends on which one as some eliminate the cat, but then still should be fine.
Old May 16, 2006 | 07:03 PM
dthug's Avatar
Default Re: Exhaust fitting question (93b18civic)
if it doesn't just go to meinike they make anything work
Old May 16, 2006 | 07:04 PM
axtran's Avatar
screw meineke, lil mom pop shops cost WAY less
and yeah if u get the motor with like a JDM header, the flange is HUGE and you will need custom work.
98LX-Wookie
Nov 26, 2011 04:14 PM
Newbster4321
Mar 7, 2006 03:51 PM
Team Bukkake Sucks!!!
Aug 23, 2005 07:38 PM
Integra99
Aug 16, 2004 01:42 PM
boostedEJ2
Dec 16, 2002 06:50 PM
