After market parts...
Hey im looking at getting the greddy evo 2 dual tip catback system and headers, for my 00 ex v6...my question is if i get these parts and install them is it going to make my check engine light come on because there are supposed to be sensors that plug in at the headers, or the cat? i guess my real question is are there sensors that will be affected by an aftermarket exahst system? thanks!
Not as long as you keep the cat inbetween the header and exhaust. If you just use a piece of pipe there and don't keep the 02 sensors yes your check engine light will come on and your car will pretty much run like crap unless you get a 02 sim or something like that.
Let me give you a very simplified desription of the entire exhaust system:
Engine > Headers > Cat > Cat-back exhaust
The rear O2 sensor plugs into the cat, which you are not replacing. Your new headers should have a bung to install the front O2 sensor. There are no sensors that plug into the cat-back exhaust, whether OEM or aftermarket.
thanks, sorry for the noobish question, but i just wanted to be make sure of that before i drop i couple 100 on headers and a cat-back system
SuciaEk420
12
Jan 21, 2012 05:00 PM
