Jacked car in the air to spin ITR LSD trans. Only one wheel spins...
Old May 16, 2006 | 02:19 PM
. M i c h a e l's Avatar
dotmichael to you
Default Jacked car in the air to spin ITR LSD trans. Only one wheel spins...
I spun both wheels, the opposite wheel doesnt move at all. Turned the car on and put it in gear. Both are moving.
I know this isnt the best way to check for LSD...but shouldnt the opposite wheel being spun move?
I called mythias and he confirmed that the opposite wheel will spin the other way.
I spun both driver and passenger wheels...both clockwise and counter-clockwise. Only the wheel being spun moves. The opposite does not.
The trans is supposedly brand new and bought from Honda as of Novemeber and has approx 3,000 miles on it.
J4D LSD has been "washed away" due to brake cleaner being spilled on it.
Old May 16, 2006 | 02:21 PM
Alexander's Avatar
Default Re: Jacked car in the air to spin ITR LSD trans. Only one wheel spins... (. M i c h a e l)
hmm.. check for this: https://honda-tech.com/zerothread?id=1625639
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1_Variable &raquo;</TD></TR><TR><TD CLASS="quote">If you have the tranny off the car just look threw the transmission where the axle and intermediate shaft go. If you can see all the way threw and there is no dif pin going threw it the tranny has LSD. Like this.
Old May 16, 2006 | 02:47 PM
dotmichael to you
Default Re: Jacked car in the air to spin ITR LSD trans. Only one wheel spins... (Alexander)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexander &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. check for this: https://honda-tech.com/zerothread?id=1625639
yeah what i'll probably have to end up doing...however my main concern right now is why the other wheel doesnt spin either way.
Old May 16, 2006 | 02:54 PM
MattD@Stoptech's Avatar
Do you have it in gear when you're spinning the wheels?
Old May 16, 2006 | 02:58 PM
dotmichael to you
Default Re: Jacked car in the air to spin ITR LSD trans. Only one wheel spins... (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Do you have it in gear when you're spinning the wheels?</TD></TR></TABLE>
No.
Old May 16, 2006 | 03:03 PM
You need to have it in gear to check.
Limited slip differential
Operational check
1-Set the parking brake and block the rear wheels
2-Raise the front of the vehicle and support it with safe stand.
3-With the engine off, shift the transmission in first gear
4-Rotate either front wheel by hand and check that the other wheel rotates in the
opposite direction.
5-If the opposite front wheel does not rotate, or if you cannot spin the front
wheels at all the limited slip differential is faulty and should be replaced.
Old May 16, 2006 | 03:05 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">For some reason I was thinking it would matter, but it doesn't.
yeah when i first did it, i forgot i left it in gear..i went oops and put it in neutral. either way it does the same thing.
Read above, my first instict was right, you need it in gear
Old May 16, 2006 | 03:06 PM
dotmichael to you
going outside to do so right now.
Old May 16, 2006 | 03:11 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">Read above, my first instict was right, you need it in gear</TD></TR></TABLE>
indeed you do. in gear, the opposite wheel spun the other way.
Old May 16, 2006 | 03:27 PM
dotmichael to you
thanks a ton diablo
Old May 16, 2006 | 03:33 PM
s2kdre's Avatar
its a gear type lsd, not a clutch type,
Old May 17, 2006 | 08:11 AM
dc2r01's Avatar
DOn't u have to be in a gear??
Easiest way to test out your LSD is hold your RPMS at 3-4k RPM and turn your steering wheel (Best to do this in a parking lot) and HAMMER the throttle! both wheels should be pulling you!
Old May 17, 2006 | 10:04 AM
JjuuN R's Avatar
Default Re: (dc2r01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2r01 &raquo;</TD></TR><TR><TD CLASS="quote">DOn't u have to be in a gear??
Easiest way to test out your LSD is hold your RPMS at 3-4k RPM and turn your steering wheel (Best to do this in a parking lot) and HAMMER the throttle! both wheels should be pulling you!</TD></TR></TABLE>
the right way to check it has already been mentioned, discussed, and tested. your comment sounds like pure stupidity to me
Old May 17, 2006 | 10:15 AM
Mugen Mike's Avatar
The only "hammering" that needs to be done is in regard to your post.
Old May 17, 2006 | 12:27 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: (Mugen Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">
The only "hammering" that needs to be done is in regard to your post. </TD></TR></TABLE>
lol.....
Old May 17, 2006 | 12:51 PM
Batoutahell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike &raquo;</TD></TR><TR><TD CLASS="quote">The only "hammering" that needs to be done is in regard to your post. </TD></TR></TABLE>
Hammer sez - this post is too legit to quit.
C5teg
Dec 21, 2007 01:17 AM
. M i c h a e l
May 16, 2006 03:23 PM
speedminded
Sep 5, 2004 06:49 PM
comptechgsr
Jan 24, 2003 05:14 PM
celica73
33
Aug 21, 2002 10:33 AM
