Are the 2.2L accord head bolts torque to yield?
I can't seem to find any information on the 2.2L head bolts in the 90 accord. Are they torque to yield type (meaning they must be replaced each time head is removed) or not?
many people dont replace them and get away with it, like the valve cover gasket if its in ok shape, the helms doesnt say it but the understanding is to replace them, but for the cost of new headbolts you can get arp studs that can be reused....
What is a good place to buy the studs, and how are they installed? Oil on the block threads like usual and then oil the stud and nut, and also what about torque? I should mention that this is a daily driver NOT a racer.
http://shopping.lightningmotor....html
These are the ones you need. They include installation instructions which is good, because I can't remember. They are great even for a daily driver because if you ever need to pull the head again, you will save a few bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I R Tylor »</TD></TR><TR><TD CLASS="quote">http://shopping.lightningmotor....html
These are the ones you need. They include installation instructions which is good, because I can't remember. They are great even for a daily driver because if you ever need to pull the head again, you will save a few bucks.</TD></TR></TABLE>
thats where i got mine from, also look in the marketplace section for his thread, the code for free shipping is in there, its something like hondatech or honda-tech but i cant remember exactly....u may want to call them cuz when i ordered them the h22 were out of stock and it took an extra 2 weeks to get them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runderwo »</TD></TR><TR><TD CLASS="quote">That one says Prelude 2.3L not Accord 2.2L. I can't find the Accord 2.2L on their site.</TD></TR></TABLE>
most h/f series parts are the same, which these are as well, if you ever need to find out look it up on http://www.slhondaparts.com, part numbers for h23 and f22 head bolts are the same
you won't find it on their site, but like everyone is saying they fit perfect. I run them myself in an F23.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master »</TD></TR><TR><TD CLASS="quote">final torque is 78 ft lbs \
do it in 3 stages
# 1 ,,29 ft lbs
# 2 51 ft lbs
# 3 78 ft lbs </TD></TR></TABLE>
NO!!!! that is only for the stock honda head bolts, if the op chooses to go with the arp head studs go by whatever arp says to, on mine you goto 80 if you use the arp lube, if you just use 10w30 on the studs you goto 120 ft/lbs....instructions - theyre there for a reason
do it in 3 stages
# 1 ,,29 ft lbs
# 2 51 ft lbs
the.hamburglar
Feb 17, 2006 06:48 AM
50shotRex
Jan 28, 2003 08:50 AM
