my new brake cooling ducts
Old May 15, 2006 | 11:58 AM
austrian type-R's Avatar
Default my new brake cooling ducts
here are my new brake cooling ducts I made:
Old May 15, 2006 | 12:00 PM
white rocket's Avatar
Default Re: my new brake cooling ducts (austrian type-R)
BADASS . I've always wanted something like that.
Old May 15, 2006 | 12:04 PM
Aquafina's Avatar
Default Re: my new brake cooling ducts (white rocket)
I like how the NACA ducts are molded. I thought it was supposed to go to the bottom of the rotor though?
Old May 15, 2006 | 12:19 PM
Dave_B's Avatar
If I was only allowed to use the turn signal area for brake ducting. I'm going to have to cut the corners of grill out and do it from there.
Old May 15, 2006 | 12:35 PM
Mugen Mike's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">If I was only allowed to use the turn signal area for brake ducting. I'm going to have to cut the corners of grill out and do it from there. </TD></TR></TABLE>
You could always do it the Matt Jensen way:
https://honda-tech.com/zerothread?id=951821
Old May 15, 2006 | 12:39 PM
Dave_B's Avatar
^^^Thanks^^^
Old May 15, 2006 | 12:53 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">^^^Thanks^^^</TD></TR></TABLE>
Absolutely not a problem whatsoever.
Old May 15, 2006 | 02:47 PM
1GreyTeg's Avatar
Default Re: (R.S.AKIMOTO)
Christian, how is the hose attached near or to the rotors? Or is it just affixed nearby? I have a similar setup with NACA ducts and hoses but haven't installed it yet (something else that I can't seem to find time to do) but have always been looking for a better way to direct the airflow to the center of the rotor not just in the general direction and I don't want to pay for anything. Thinking of making a air director like the one D had started years ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.S.AKIMOTO &raquo;</TD></TR><TR><TD CLASS="quote">We sell a Spiral Flex tube that is used by several offroad & rally teams for the same purpose...check it out...
looks like home dryer ducting from Home Depot to me.
Old May 15, 2006 | 02:52 PM
diversegsr's Avatar
Default Re: (Mugen Mike)
thats a good thread...
Old May 15, 2006 | 03:21 PM
Kavehman's Avatar
Question would this kind of duct, make a good source of air for an intake ?
or why would you not do this for an intake instead ?
Old May 15, 2006 | 04:00 PM
itr1244's Avatar
that's nice
Old May 15, 2006 | 04:14 PM
Dave_B's Avatar
Default Re: (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">Question would this kind of duct, make a good source of air for an intake ?
or why would you not do this for an intake instead ?</TD></TR></TABLE>
I would guess it's because the ID of the tubing is not smooth.
Old May 15, 2006 | 05:01 PM
Jet Phi's Avatar
whoa that's awesome
Old May 15, 2006 | 05:12 PM
d.n.d.'s Avatar
cool stuff
Old May 16, 2006 | 05:42 AM
ambrozic's Avatar
awesome. tell us later how it proves on track.
Old May 16, 2006 | 06:09 AM
P1_Variable's Avatar
Default Re: (ambrozic)
I have images in my head of that becoming a crank pulley cooler aswell pretty soon. I would try and move that away from it man.
Old May 16, 2006 | 06:23 AM
Track rat's Avatar
Default Re: (P1_Variable)
You can make a small bracket, support it by one of the oil pan nuts, and zip-tie the brake duct to the bracket to prevent rubbing on the crank pulley.
Old May 16, 2006 | 08:52 AM
Default Re: (Track rat)
Good call.
Old May 16, 2006 | 09:22 AM
Dat1BVtecN's Avatar
haha, looks sweet man
Old May 16, 2006 | 09:26 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">You can make a small bracket, support it by one of the oil pan nuts, and zip-tie the brake duct to the bracket to prevent rubbing on the crank pulley.</TD></TR></TABLE>
Your car is the one I'm modeling mine after.
Old May 16, 2006 | 09:44 AM
JjuuN R's Avatar
good stuff Christian
Old May 16, 2006 | 10:50 AM
Padawan's Avatar
Darth ModerVader
Would the duct openings in the bumper not be more effective if the ducting met them farther back (i.e, with less of the ducting "sticking out" of the duct openings), so that a greater volume of air was directed into it? Just a thought, but either way, nice work.
Old May 16, 2006 | 11:55 AM
Track rat's Avatar
Your car is the one I'm modeling mine after.</TD></TR></TABLE>
...then get it finished and get out there!
John W and I had a great weekend at CMP. We turned fast laps just tenths apart during the races; he won Saturday, I won Sunday. Good Stuff!
Join us!
Old May 16, 2006 | 11:58 AM
Dave_B's Avatar
Join us!</TD></TR></TABLE>
Soon, I'm finishing up a few things and then we'll see what happens. You guys gotta play nice when I first get out there. All I've been thinking about since CMP last year out of the last turn, was DAMN these guys will be all over my ***. Then the thought of bump drafting came to mind. That's still a scary thought.
Old May 16, 2006 | 12:08 PM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">BADASS . I've always wanted something like that.</TD></TR></TABLE>
Me too.
So how do they work? How would you test it? A few laps with out the ducts; laser thermometer test. Then a few laps with the ducts; laser thermometer test. Compare?
